Old 05-31-2010, 03:54 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default Plastic Brake lines/fittings
I am soooo tired of leaks in the plastic brake fittings between the firewall and master cyls. Tried a search but no joy so what's the best alternative to these? Is anyone making a kit with better quality components? I saw one post that mentioned SS lines but that was on the gear legs replacing alum.
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 05-31-2010, 04:33 PM
Tony Spicer Tony Spicer is offline
This from Randy Lervold works on the -3 and -8, but don't know if it fits on the -6:
http://www.romeolima.com/RV8/IdeasPr...e%20Reservoirs
Tony
Old 05-31-2010, 04:43 PM
If they fit the 9 they should fit the six.
Old 05-31-2010, 07:16 PM
dedgemon's Avatar
dedgemon dedgemon is offline
Default Aviation dept of Home Depot
You can use standard brass 1/4 inch compression fittings ala ice maker. Much better than the nylon tee that Vans keeps sending along.
David Edgemon
RV-9A N42DE
RV-8 N48DE
whats next ??
Track me!
Old 05-31-2010, 08:05 PM
Brantel's Avatar
Brantel Brantel is offline
SS braided lines are the way to go! Call Bonaco! They have a kit fully developed and they advertise here.. Search the archives, tons of info!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 05-31-2010, 10:01 PM
ArVeeNiner's Avatar
I've replaced most of mine with SS braided ones from http://anplumbing.com/.
I'll probably replace the rest after I'm flying.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
Old 06-01-2010, 02:16 AM
ron sterba ron sterba is offline
Call Bret at BONACO. There listed on the sides of the forums pages in company ads. Iam putting in a parking brake and i spoke with Bret and he helped me and i'll be ordering the lines from him. Like one of the guys said Bonaco has a kit for BOUT $180 IN ss for the 9 & 7. Ron in Oregon. Tell Bret I sent you!
Old 06-01-2010, 05:51 AM
Finley Atherton Finley Atherton is offline
You could consider using Nylaflow tube (not Nylo-Seal) with the appropriate brass Poly-Flow fittings ( both available from ACS).
Nylaflow (3/16") was standard for the brake lines from the Master cylinders to the brake calipers on the Vari-Eze and LongEze and generally gave very good service. Over 26 years I never had any leaks in the Nylaflow brake lines or fittings on my VariEze. Rutan's recommended procedure was to install a short length of 1/8" OD brass tube into the end of the Nylaflow where it fits into the brass fitting to give something more solid for the brass sleeve to tighten against.
Fin
9A
Vari-Eze
Old 06-01-2010, 07:13 AM
Wayne Gillispie Wayne Gillispie is offline
Default 5052-O .035"
for fuel and brake lines just ordered from AS.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 06-01-2010, 07:15 AM
Default brake lines
Braided teflon is the best solution. A friend installed some on his RV-6, with great results. Kits are great as long as the lengths are correct. The great thing about you building YOUR plane, is that your accessories and bulkhead fittings might not be exactly where the next builder put his. Test fit them first. Properly secure them, and they will last the lifetime of the plane.
Tom
Ridgeland, SC
