Old 05-31-2010, 11:20 AM
jimbo jimbo is offline
Default ? on wire bundle tie downs
This has been bugging me and I am hoping I can get great advice from the electrical gurus out there.
The Aircraft Inspection and Repair Manual AC 43.13-1B in the electrical section says to secure wire/wire bundles every 2 foot max and that the max wire deflection should be no more than 1/2" between secure points when a slight pressure is applied 90 deg to the wire in midspan.
I know "adel" clamps are made for this purpose but sometimes these are a problem to bolt/screw on-maybe there is no access to the back side of the rib you are bolting it to and to install a nutplate may be difficult. Are there other ways I am missing? I have seen on bldrs web sites some use a nylon block type of device that a wire tie runs thru. This block is attached to the rib w/ adhesive backing. Not sure this is a good way as seems like the adhesive could dry out and come off. I am using rib as an example here but could be anything you are securing the wire to.
Are there simpler ways I am missing? And if there are special secure type fittings beside adel clamps where can you buy them?
Jim
RV9A Fuse
Old 05-31-2010, 02:37 PM
ccrawford ccrawford is offline
Couple of options I've found..
You can use the nylon blocks, though some folks like to secure them better than the sticky backing - either high strength glue or a pop rivet. I find the pop rivet gets in the way of the zip tie, but maybe I don't have small enough rivets.
Alternatively, you could use rivnuts for adel clamps. Kinda pricey, but don't require access to the back. Examples here:
http://www.aircraftspruce.com/catalo...es/rivnuts.php
// corey crawford
// rv-7a (sold)
// denver, co @ KBJC
Old 05-31-2010, 03:06 PM
FlyingArcher's Avatar
FlyingArcher FlyingArcher is offline
Default Click-Bond
Another option is to use Click-Bond products that are adhesive.
You'll find them at The Flight Shop, I think they advertise somewhere on this site.
I have purchased their wing-tip kit but not yet used it so I can't report on effectiveness, but if you search this forum you'll find a lot of happy customers
Daniel Mouly
VAF #778 - [2013 payment done]
RV-9A Emp. & Wings 95%, Fuse 70%
Austin Healey 3000 MKIII fully restored
LFCD (Andernos Les Bains), France
Construction Log comments in French (not really up to date, sorry)
Old 05-31-2010, 03:52 PM
erich weaver's Avatar
Hard to get simpler than the nylon block. Scrape off the sicky tape backing that is provided, clean the surfaces, and use a shoe-goo type adhesive. pretty cheap for the airplane world, and it aint coming loose.
erich
Old 05-31-2010, 05:51 PM
az_gila's Avatar
az_gila az_gila is offline
Smile I like these with...
...a pop rivet. The AZ heat can get to the sticky back mounts...
http://www.aircraftspruce.com/catalo...tiemounts1.php
The second one down will work for most of our small cables with a 1/8 pop type rivet.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-31-2010, 06:08 PM
Default Thats the ticket
Gil....I haven't seen those up close. Didn't find them in the ACS catalog (maybe they are only in the online catalog). Those are what I am looking for.
Jim
RV9A fuse
