Old 05-29-2010, 07:19 PM
N941WR's Avatar
N941WR N941WR is offline
Default Baffling question
I'm just about finished with the baffles on my new engine and this question is for those who have done multiple installations, one with the safety wire and another with the new SS rods.
I never had a problem with the safety wire but if there is a compelling reason to use the rods, then I'll install those.
Which is better?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-30-2010, 05:46 AM
apkp777's Avatar
apkp777 apkp777 is offline
Bill, everyone's quiet on your question. I actually just fabbed one SS rod yesterday and promptly decided to use safety wire instead. I ran out of .041 so I will have to get some more, but my plan is to use a double wrap around a steel hinge pin section then thread the twisted wire through the hole then through a section of vacuum hose then secure with another hinge pin section.
The SS rod sucks and it's hard to get the right tension and still avoid any chafing.
Of course, I have not done this yet so I may change once I get to it.(Tuesday)
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 05-30-2010, 06:10 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default baffles
Bill,
I'll confuse you a bit.
On my Superior O-320, I opted for a threaded SS rod. I actually used hinge pin, and threaded it 4-40. I was able to bend angles in it to clear the inter cylinder baffles, and it was easy and looks real nice too. I check them every time I have the cowling off, and I have yet to adjust or tighten them.
I have seen quite a few installations with saftey wire, and that appears to work well too, but mine was not a straight shot from end to end, so the rods were a better choice for me.
Hope this helps...
Chris.
PS ....Check your PM's for an Emag question....
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 05-30-2010, 06:42 AM
N941WR's Avatar
Tony & Chris,
Thanks for the comments. I might just go with the safety wire because it is less parts to deal with.
On my old baffles, I put a pop-rivet through a small AN washer and then through the hole on the tab. After that I punched the center of the rivet out. This kept the wire from working the baffle. Here's a picture:
Bill R.
SC86 - Easley, SC
Old 05-30-2010, 06:48 AM
apkp777's Avatar
Originally Posted by N941WR View Post
On my old baffles, I put a pop-rivet in the hole on the tab and then punched the center out. This kept the wire from working the baffle.
That's a great idea! I think I'll do the same.
Tony Phillips
Old 05-30-2010, 08:00 AM
N941WR's Avatar
PS. Tony, check my post above. I clarified it a little by adding the part about using the pop rivet to hold a small AN washer in place.
Bill R.
SC86 - Easley, SC
Old 05-30-2010, 04:34 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Baffle rods Vs .041
I had used .041 SS wire on my Long-EZ baffles. Over time, I had problems with the SS wire cutting into the Al baffle holes. On my -9A I went with the SS rods. Yes, it was a PITA, but I think it makes long term maintenance sense.
http://www.mykitlog.com/users/displa...g=89570&row=26
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 05-30-2010, 08:39 PM
apkp777's Avatar
I installed the SS rods. It took an hour or so to fab them. I am pretty sure they will be disposable when it comes time to remove them. But they look good right now.
Tony Phillips
Old 05-31-2010, 05:43 AM
Steve Steve is offline
I used the safety wire for a second time when I replaced my #4 baffle assy (using Vans supplied new design parts) even though I could've used the threaded rod. 'Course then #2 baffle would've needed modification.
Five Sierra Fox
RV-9A
Utah
Old 08-08-2010, 05:36 PM
Lars Lars is offline
Default vans st. steel tie rod material
I attempted to make the tie rods today using the material supplied in the kit- the plans show it, how hard can it be? That is some seriously hard stainless steel rod.
The stuff in my kit measured 0.113" diameter, thus way under the nominal 0.136" diameter for a normal #6 thread. Even so, I managed to destroy a brand new, very expensive US-made high speed steel die by the time I had threaded three of the four rods. I even held everything in alignment on my lathe, which I turned by hand, backed up frequently to break the chips, used high quality cutting oil, etc.
Yes, I know there are easier and possibly better ways to do this, but I was being (extremely) stubborn. Thus pushing my completion date out a little bit farther. Again.
Switching to Plan B...
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
