Old 05-28-2010, 08:10 PM
BillSchlatterer BillSchlatterer is offline
Cool Pressure testing QB tanks ??
I would assume that the QB tanks have been tested but that might not be a great assumption. Since they are installed on the QB wings, you can't see the backs of the tanks anyway so I was just wondering if some, most, or everyone is actually pressure testing the QB tanks?
Is it common or rare that a QB tank will leak?
Bill S
7a almost there
Old 05-28-2010, 08:16 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I tested mine after the covers and senders were installed. Be sure and remove your covers to ensure the pick up tubes are secured properly. I found no leakage in mine, but some builders have found leaks in theirs. Always wise to test prior to filling with fuel. Simple balloon and manometer tests are available.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 05-28-2010, 08:21 PM
Radomir's Avatar
Radomir Radomir is offline
I didn't test mine and have no leaks.. all's good.. been flying 2.5 years
Radomir
RV-7A sold
Old 05-28-2010, 08:52 PM
kevinh's Avatar
kevinh kevinh is offline
Test em - it is super easy and better to find a leak now than when you've put it together at the airport (possibly even painted)
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 05-29-2010, 12:21 PM
gasman gasman is offline
Originally Posted by BillSchlatterer View Post
Since they are installed on the QB wings, you can't see the backs of the tanks anyway.
Bill S
7a almost there
The tanks come installed on the wings for shipping only! They need to be removed, inspected, tested and then installed as per instructions.
