  #11
Old 02-21-2006, 06:26 AM
N395V's Avatar
N395V N395V is offline
for an avionics/starter safety interlock
Does this mean that if for some reason you had to restart in flight you wuld have to turn off all the avionics/EFIS etc. Or are you planning a 2nd battery with an avionics bus?
Milt Concannon
Old 02-21-2006, 07:03 AM
fodrv7's Avatar
fodrv7 fodrv7 is offline
Default Lateral
Oooh!
A lateral thinker.
Peter James.
Australia Down Under.
Old 02-21-2006, 07:16 AM
Mel's Avatar
Mel Mel is offline
Yes, that is one consideration of having the starter wired through the avionics master. But, how often do you need to "restart" during flight. If the engine stops during flight, it stopped for a reason. The prop will continue to windmill, so the starter is not needed. If the prop stops, you have a real problem and the starter probably isn't going to help anyway. If you think this will be a problem in your case then I recommend that you not do it. For me it's been working for 13 years.
Mel...DAR
Old 02-21-2006, 12:12 PM
szicree szicree is offline
EFIS? I ain't got no stinkin' EFIS. Switch off the avionics, hit the start button, avionics back on. No big deal. Besides, if you restart without turning off the radios and such, isn't there a chance you'll toast them?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
