Old 05-26-2010, 10:45 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default fuel filter needed before FloScan on 0-320?
Following the reasonably positive experience of others, I decided to put my FloScan between the valve and the aux pump in the fwd tunnel. However, after I installed it I discovered that Dynon recommends a filter upstream of the transducer. I didn't leave room to do so but am wondering if I need to rework my lines to make a filter fit.
What's the likely failure mode for not using the filter? Would debris likely clog the transducer (and cause fuel starvation) or would it just make the fuel flow reading questionable?
FWIW, I have an O-320 (no fuel injection).
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 05-27-2010, 01:29 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
There is talk of which fuel flow sensors have "bypasses" and which do not... and clearly ones which do not will be more vulnerable to stopping your engine. However, in the ultimate case, even the bypass is likely to be more prone to obstruction than straight pipe.
I've just done the test flying on an RV where, despite apparent best efforts, a load of swarf ended up in one tank. Given the extra heart beats incurred with 3 flights returning with limited power *, I would advise following Dynon's advice and filter before any areas vulnerable to obstruction.
Andy
*For info, the swarf visible in the fuel filter after these flights was considerable, but not enough to restrict fuel flow. The problem was the "in line filter" in the injector body - a "re conditioned" unit. The size of particles required to restrict flow through this got through the filter (Airflow) and were probably not visible. They made the filter very hard / impossible to blow through, and restricted fuel flow through this filter with the electric pump on to approx 50% of that with the filter cleaned... which was done with an ultrasound machine(?) We suspect that filter might have had some corrosion on it which made the already fine holes somewhat smaller? It's being replaced!
Old 05-27-2010, 03:29 PM
Thanks Andy.
Does anyone have any recommendations about what would make for an appropriate fuel filter to use just upstream of the fuel flow transducer? I've checked Spruce, but am not sure exactly what I'm looking for in terms of type and micron level.
Also, if anyone else has pictures of their installation, especially how they modified the center tunnel (if at all) to fit everything in, I'd MUCH appreciate it.
Steve M.
Ellensburg WA
Old 05-27-2010, 03:50 PM
Walt's Avatar
Walt Walt is offline
Default What I use...
Flow Ezy MODEL 3ILA - 5 gpm / 250 psi / 5.2 oz. ANODIZED ALUMINUM PERFORMANCE RACING FILTERs - Increased volume means more flow. This filter package sports the excellent design of the ILA and 2ILA and combines that technology to create a filter kit that boasts a 5 gpm rating with a minute increase in volume and weight. 74 micron filter.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-27-2010, 04:04 PM
Thanks Walt. Couple questions:
1. Where did you get it? (can't find it in Spruce)
2. Why did you choose the 74 micron version? (The 31A has multiple versions, and I don't know one from the other.)
2. How far upstream is your filter from the transducer? (Dynon suggests 6 inches of straight run in and out of the FloScan. Does having a filter immediately upstream contradict this requirement or is the six inches just meant as a recommendation or prohibition against bends or elbows?)
Steve M.
Ellensburg WA
Old 05-27-2010, 04:13 PM
Walt's Avatar
Default Filter
You can get them direct from Flow Ezy...
http://flowezyfilters.freestarter.com/
(6T is the fitting size you need, filter size is 74 micron recommended size from flo scan and the pump makers)
I put mine right after the fuel selector on the floor.
Old 04-18-2012, 01:14 PM
Does anyone who has used two filters (1 on each side) between the tanks and fuel selector have pics showing how and where they installed them? It would be a retrofit for me so access and ease of installation is important. I'm thinking the most logical at this stage is fwd of the spar under the covers, but perhaps in the wing root if I don't need to do a lot to support the filter body itself.
Also, I'm looking for a bit smaller filter than the Flow-Ezy 3ILA. Whatever filter I choose, I will be using a 74 micron stainless steel per Floscan instructions. At 4gpm, and 12" of surface area would the 2ILA be appropriate or do I really need the 5gpm and 20" surface area of the 3ILA? http://www.flowezyfilters.com/image_...log%202009.pdf (see p. 2-4)
I'm always reluctant to make any modifications to something as critical as the fuel system, so thanks for the help. (One of the disadvantages of putting the Floscan in the cabin.)
Steve M.
Ellensburg WA
Old 04-18-2012, 05:59 PM
chaskuss chaskuss is offline
Whoever you get one from, be sure to specify Flourosilicone or Viton O-ring if you plan on using unleaded gas. I believe that Bendix [and all subsequent owners of Bendix fuel injection systems] specify a 74 micron [approx. .003"] filtration. That should be more than adequate for a carburetor, as they are not as sensitive to small debris in the fuel.
Charlie
Old 04-18-2012, 06:44 PM
Tony Spicer Tony Spicer is offline
I'm using a 2ILA-6T-40 in my O-320 with no problems. Photo here. If you use two filters mounted upstream of the valve, you'll have to drain the tanks to remove the filters.
Tony
Old 04-19-2012, 02:57 PM
Viton o-rings. Good point. Will likely experiment with mogas in the future.
Originally Posted by Tony Spicer View Post
I'm using a 2ILA-6T-40 in my O-320 with no problems. If you use two filters mounted upstream of the valve, you'll have to drain the tanks to remove the filters.
Thanks for the first-hand experience Tony. I think I'd just have to make sure that the fuel in the tanks was lower than wherever I installed the filters, right? Particularly for the taildragger, I think I could mount them just forward of the spar (on the RV-9) under the covers where they would be pretty much the same height as the fuel selector and well above the tanks. Those smaller 2ILF filters might also fit in the wingroots without too much effort, but I'd probably need to find a way to support them there.
Still trying to decide about 2 upstream of the valve or 1 just downstream of the valve before heading into my Floscan. Kind of trying to avoid a single-point failure issue, though I'm not really sure if that is an issue with a quality filter like a FlowEzy with 74 micron stainless screen. I know just enough to know what I don't know!
Thanks again for all the help.
Steve M.
Ellensburg WA
