Hi Andy. Thank's for the advice and yes, I have been to Randy's web page. The previous induction system in this particular 3, as I recently learned, was similar to the Piper Comanche... drawing induction air from the right rear cylinder baffle and allowing a clean air scoop free bottom cowling. So it can be done with out modifing the bottom cowl!
I talked to a Mustang II owner recently who installed a Piper Comanche injected 320 engine in his plane with the Piper (off the rear baffle) induction setup, evidently with no problems. He included a flight journal of a flight to Alaska!
I'll post this for the RV-3 group, as well.
Dave
Hi Dave.
I am not 100% sure of what you are trying to achieve... however, see
Randy Lervold Link for some issues of RV-3s v IO-320 engines. In short the cowlings are not large enough to contain all engine induction arrangements, and might need to be reworked, even to the extent of using an RV-4 one (as Randy did).
It might be worth including RV-3 in the thread title, and/or putting it in the RV-3 section - the number of RV-3 experts is small, and anything to draw their attention may help.
I'd appreciate any updates, since we are building an RV-3, and will need to configure and fit an IO-320 engine
Andy
RV-8 G-HILZ[/quote]
