Old 05-26-2010, 11:02 AM
Fearless's Avatar
Fearless Fearless is offline
Default Brian Wallis has a write up in AOPA magazine
Brian Wallis has a write up in the current AOPA Pilot magazine. Way to go Brian.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
Old 05-27-2010, 05:06 PM
brianwallis's Avatar
brianwallis brianwallis is offline
VAF moderator
Talking Hello
I do believe you are correct sir... Thank you for catching that, can't say I've seen the hardcopy myself.
http://m.aopa.org/members/files/pilo...ne/frugal.html
I've been slammed working on a Cropduster that had sand put in the fuel AND oil... Details if you ask.
Best
Brian
Brian Wallis
(Exempt AND VAF dues paid 02 FEB 16)
Callsign: VOODOO sold RV3 to pay for ratings !!!
AP/IA COM/Multi/IFR/350 type
Old 05-27-2010, 05:45 PM
TSwezey TSwezey is offline
Great article!
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 05-27-2010, 07:25 PM
turbo's Avatar
turbo turbo is offline
Talking just one ?...........
how did that happen? dirt? dito on nice writeup!!!!!!!!!!!!
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 05-28-2010, 07:22 AM
VAF moderator
Default Dirty.....
Yes.... I can't say much now because of the investigation however, there are a few things I can share. The first is that the oil screen on the back of the engine split along the joint because of so much metal (clogged screen = pressure) in the screen. I've never seen that in person before. There was grit in the oil when I removed the oil pan and drained it into a bucket over some fine straining cloth. The full article is in AG Air update. There was fine white sand placed in the Rt tank. It took a lot of work to swap/clean/replace everything and apparently Homeland Security and whoever else has there unders in a square knot over it. The "oh this is the best 188 I've ever seen" annual went from two full days to well over a month of torture. It's scary to see that someone tried to kill somebody and now you are doing the annual. You have to assume that it was someone that really knew what they were doing and that they were as sneaky as they come. You have to check everything about everything.... It's as close to rebuilding the aircraft as it gets. I've found multiple cotter keys removed from the flight controls and who knows what else. Attempted Murder charges are waiting on whoever it was... it could of been multiple people. There are lots of other interesting details.... but all in time my friends. It was really a blue pill or red pill experience(matrix). Which pill do you take? How far down the rabbit hole do you go? The further we went, the more we found. Use your imagination and don't disappoint me. Scary scary scary..... She is much better now
Best
Brian Wallis
Brian Wallis
Old 05-28-2010, 10:09 AM
DEWATSON DEWATSON is offline
Brian,
The article in AOPA is just right. Congratulations on the exposure. It should be good for you.
Please be careful with the publicity the ag plane fiasco has created.
I hope all is well.
David Watson
49FD
