Old 05-26-2010, 10:22 AM
jaradtke's Avatar
jaradtke jaradtke is offline
Default Carburetor Temperatures
Looking for a little input for some prospective.
What kind of carburetor temperature reading are you guys getting compared OAT, during cruise?
Jeff Radtke
Lutz, FL
RV-7A - SOLD
RV-7A - New Build
Tail Feathers - Complete
ER Wings - Complete
Fuselage - Complete
Finish - Started
Old 05-26-2010, 10:52 AM
elippse elippse is offline
Default Carb temp
I have a temp probe at the outlet of my carb. In a recent test at 3000', 4350' dalt, 203 mph, 21C OAT, I was seeing 18C-19C carb temp. The stagnation temperature rise into the carb inlet should have been about 4C, giving an inlet temp of 25C, so the drop was 7C-8C. This is a little more than I would have expected for two reasons; CF Taylor says that the typical temperature drop due to fuel evaporation should be about 24F, 13C, and my carb is on a fiberglass extension on the back of my carbon-fiber pan and should see less conductive heating than the typical Lycoming set-up on the bottom of the pan. 'Can't explain the 5C-6C difference!
