Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
Old 05-25-2010, 04:41 PM
FresnoR's Avatar
FresnoR FresnoR is offline
Default Opposed Piston Cylinder Engine
Check out this engine in development by the company, EcoMotors.
Looks like the majority of their financing is done through the Department of Defence. Looks like it could be a promising engine in the future.
http://engineeringtv.com/video/Oppos...posed-Cylinder
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 05-25-2010, 06:02 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Huh, interseting. Back to the large cheeks ala -4's.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 05-25-2010, 07:23 PM
G-force's Avatar
G-force G-force is offline
James Atkinson would be proud...he designed and patented an engine with opposing pistons in the 1880's. Although his differential engine was a 4 stroke, it just shows that there is not much that has not been tried...we just get better at it as time goes on
Mike Sumner
Castaic, Ca
Old 05-25-2010, 07:27 PM
Andy_RR Andy_RR is offline
Default definitely not much new out there...
I've been reading a book first published in 1933 that describes a production common-rail diesel fuel injection system with electromagnetically actuated injectors!
Old 05-25-2010, 07:38 PM
John Clark's Avatar
John Clark John Clark is offline
Default Not much truly "new" out there
Electric vehicles, hybrid vehicles?
http://tinyurl.com/2d9pr6m
John Clark
RV8 N18U "Sunshine"
KSBA
Old 05-25-2010, 08:33 PM
G-force's Avatar
There were electric vehicles before the Model T!
John Clark
RV8 N18U "Sunshine"
KSBA
Mike Sumner
Castaic, Ca
Old 05-27-2010, 01:29 PM
Denase Denase is offline
Default Confused
It is my understanding that a piston's stroke is somewhat tied to its diameter. Compression either too high or too low becomes the limiting factor. If you have two pistons won't each have to travel 1/2 of that distance? If the throw of the crank is one half doesn't that then reduce the available torque? I don't see the advantage to this engine. What am I missing?
Old 05-27-2010, 01:37 PM
G-force's Avatar
Torque does not seem to be a factor in designing this engine. They appear to be going for high HP per weight and economy. 2 strokes give a power every stroke and typicaly have less losses by having less moving parts. I'm going to guess this will be a pretty high RPM motor since the usual limiting factors (piston speed) have been changed.
Mike Sumner
Castaic, Ca
Old 05-27-2010, 07:41 PM
aerhed aerhed is offline
I liked this one better.
http://www.dself.dsl.pipex.com/museu...xial-IC.htm#dy
