Old 05-25-2010, 12:02 PM
algrajek algrajek is offline
Default Fuel Flow sensor Installation
I know this subject has been brought up before but... I know a lot of you with fuel injection are putting your EI Ft60(red cube) in line, between the Servo and the fuel divider, as was I, but aftyer talking with Pete at Precision Airmotive today, I am having second thoughts. He suggests mounting the sensor BEFORE the servo to get a better reading, and more importantly, he is not comfortable having ANYTHING between the servo and the fuel distributor. Now I dont know what to do.
Any thoughts??
Al
Al "Nordo" Grajek
repeat offender
\___(0)___/
RV8
RV8A
RV8
RV6A
Now RV7A!!
Old 05-25-2010, 02:09 PM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Could you please elaborate his concerns and how it equates to a better reading?
I don't see the discomfort with having it between the spider and servo. A blocking failure on these would seem to be highly unlikely and does it matter if the main fuel line is blocked before or after the servo as either way will kill the flow.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 05-25-2010, 02:11 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Fuel flow xmitter
The best place for the FT is in a straight section of tubing so there is minimal flow disturbance from any bends and in a "cool" location, to avoid bubbles. I put mine on the floor between the fuel pp and firewall.
http://www.mykitlog.com/users/displa...=33990&row=114
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 05-25-2010, 02:26 PM
DanH's Avatar
DanH DanH is offline
I'm guessing his objection to a location between servo and spider is structural. Very few builders are providing a solid bracket to mount the red cube, thus the mass of that aluminum block is left to flail about suspended in space only by the connecting fuel lines.
Is this a bad thing? Well, it certainly was when a builder tried to suspend it on a hard line. Plus the fittings are smaller on the servo outlet side, and nobody knows what the resonant frequency might be for the hanging assembly.
Precision has been sued a few times. Can't blame them for conservative recomendations.
BTW, mine is on the firewall.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-25-2010, 02:30 PM
Brantel's Avatar
Brantel Brantel is offline
Dan,
I see teaser pics of your project all the time on here....Is there somewhere I can go to see this project documented? Your work looks amazing! At least what I have seen of it does!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 05-25-2010, 02:41 PM
One of his concerns was any kind of disruption of the fuel going to the spider. He mentioned pulses etc. that may be induced by the sensor.
It seems like it may be easier, anyway to put the sensor between the engine driven pump and the servo inlet, by just cutting the supply hoses and inserting 2 fittings. Probably sounds easier than it is.
Al
Al "Nordo" Grajek
repeat offender
\___(0)___/
RV8
RV8A
RV8
RV6A
Now RV7A!!
Old 05-25-2010, 02:45 PM
JonJay's Avatar
JonJay JonJay is offline
Default Interesting,
I know he cruises the forum so maybe he can chime in as to why...
However, here is the link to the EI installation instructions. The interesting thing here is that is shows a Flow Scan in the RV7 example and the Red Cube in the 8 example. Additionally, unless hidden, it appears the Red Cube is mounted to hard tubing suspended in free air. Bad idea.
JPI's instructions for the flow scan are to mount it on flexible line, in free air. Mine is mounted on the top of the engine between the divider and the baffle unsupported on flexible fule line.
http://www.fdatasystems.com/Manuals/FT_60_install.pdf
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-25-2010, 03:23 PM
N427EF N427EF is offline
Default Installed in my 8
I highly regard the professionals at EI but I did not like their recomended spot for the red cube installation. (on the vertical line to the spider)
Mine has a constant flow return but only one flow transducer installed just before the fuel line enters the fuel servo. The return comes out of the engine driven fuel pump and does not affect fuel flow readings. Readings of pressure and flow are extremely accurate.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 05-25-2010, 03:39 PM
Bavafa Bavafa is offline
I spoke to him regarding the installation and this instruction and he clarified that those instruction is not from EI and it should not to be followed at all which I agree with him. Connecting the red cube on hard line without any support such as pictured here is very dangerous. Having said that, I have installed mine in the tunnel and it is physically supported/mounted to prevent any vibration. The reading has been amazingly accurate, well within 0.013 of a gallon accuracy which is pretty darn good for me, I have about 1/3 of gallon discrepancy for every 25 gallon of fuel.
The fuel flow reading has been very stable as well, it goes up momentarily when I turn my fuel pump on and after a couple of seconds or less it comes back to what it was reading before. I like it in the tunnel because it has made the installation safe for my standards.
Hope this helps.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 05-25-2010, 05:09 PM
Tom Martin Tom Martin is offline
Over the years I have mounted the fuel flow sensor in a lot of different locations. From my experience I would have to say that all locations work well as long as the unit is installed properly.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
