Old 05-24-2010, 06:28 PM
AaronG AaronG is offline
Default Recommended Oil Levels for IO-540
I'm sure this question has been asked before, but I can't seem to find it with the search engine.
What is the recommended oil level for an IO-540-D4A5?
It can hold 12 quarts, but I suspect you need to use much less than that.
For my RV-8A, anything over 5.5 qts on the 8 qt sump quickly exits the engine.
Aaron
Old 05-24-2010, 06:38 PM
bcondrey bcondrey is offline
I NEVER have more than 10 in the sump and then only after a fresh oil/filter change. I keep mine between 9 and 9.5 although I suspect there are some that run even a little less. Defintely anything over 10 will blow out very quickly.
Bob
RV-10 N442PM
Old 05-25-2010, 12:15 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Holy cow.......... we put in 8 and it seems to prefer 7.
Our leak downs are good too....5% typically. Has been this way since new.
We started using 9 but it seemed to pump it out all the time.
What does everyone else think?
Old 05-25-2010, 04:44 AM
f1rocket's Avatar
f1rocket f1rocket is offline
I typically ran between 7 and 9. Like Bob, I never put in more than 10 during an oil change, which resulted in a level of 9 once the filter filled up.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 05-25-2010, 04:51 AM
Kahuna's Avatar
Kahuna Kahuna is offline
I find anything more than a 9.5 stick reading doesnt stay. I hold mine round 9.
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 05-25-2010, 05:09 AM
pierre smith's Avatar
Default Ditto...
...for me too,
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 05-25-2010, 07:12 AM
ScottSchmidt's Avatar
ScottSchmidt ScottSchmidt is offline
Super Moderator
Default 9-10 for me
I will add at our just below 9 quarts. Just like everyone has said, anything over 10 will exit the engine.
Scott Schmidt
Salt Lake City, UT
RV-10 N104XP (1280 Hours)
RV-12 N321UT (Sold)
Old 05-25-2010, 08:28 AM
dmaib's Avatar
dmaib dmaib is offline
eight seems to work best for me
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 05-25-2010, 10:57 AM
vic syracuse vic syracuse is offline
Super Moderator
Yes, I agree with the less than 9 theories. I try to keep it at nine and it doesn't want to stay there. I've only got 90 hours on it, but am about ready to see what it does at 8.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 05-25-2010, 12:29 PM
Space Cadet's Avatar
Space Cadet Space Cadet is offline
Default 11 gallons
I've got 11 gallons in mine right now
...in storage.
RV-10 #40762 - 100 hrs+
Denver, CO
