05-24-2010, 10:43 AM
Help with Elevator Attachment
Having trouble getting the bolts into the hinges with respect to the elevator attachment. Cant get my fingers in there. Thinking about using a pair of needle nose pliers to get the bolts in there. Anybody got any other tips?
05-24-2010, 10:57 AM
Is this final attachment? If not, do yourself a favor and get a set of temp assembly pins: http://www.averytools.com/pc-240-116...mbly-pins.aspx
Or make something similar. They really make attaching control surfaces a breeze. Otherwise, I can't help ya as I have yet to bolt on any of my control surfaces.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
05-24-2010, 10:59 AM
10 elevator attach
Vindino, your suggestion to use the plyers is a good one. I filed a round spot on each grip side, then smoothed them to hold but not scratch the bolts. The rounding holds the bolt quite well. Washers are another issue. I used tape to position them.
Tad Sargent
05-24-2010, 11:01 AM
thanks for the info ill check it out.
05-24-2010, 11:23 AM
Get Avery tools washer wrench set...
....for ease of inserting washers in tight areas:
http://www.averytools.com/p-242-washer-wrench-set.aspx
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
05-24-2010, 11:33 AM
Awesome info, thanks guys!
05-24-2010, 11:34 AM
Needle nose pliers is about the only way without going crazy!
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
05-24-2010, 11:53 AM
just ordered the pins and washer pliers. Going to get a cheap pair of needle nose and grind out the jaws tonight. hopefully that will lower the anxiety level!
05-24-2010, 11:54 AM
The washer wrenches from Avery's are worth 10 times their weight in gold!!!
05-24-2010, 04:34 PM
I use a pair of medical clamps. Don't recall the name perhaps forcepts. There long pliers, you cannot apply much force but they lock onto the bolt and you can focus on lining the bolt up rather than keeping it pinched. I find it frees up your hand.
