Old 05-23-2010, 09:59 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default Circuit help needed
My 10 is equipped with a stall warning horn that the previous builder installed.
In checking the stall system, I have now found that the sound level of the factory horn is woefully inadequate.
I am looking for a simple electronic circuit that will generate a signal, that can be input into the intercom, in lieu or the factory horn. My PS intercom will accept audio warning inputs.
I figure the knowledge is out there in the VAF database, so if someone knows of a chip, or simple circuit that works on 12v, and will make a really obnoxious tone that can be controlled by the factory stall vane switch, please let me know.
I am trying to work with what I already have, so the idea of installing an AOA is not high on the list of options.
As always, thanks in advance to all.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-23-2010, 11:43 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Something like...
Something like this might work for you. I haven't studied it in detail, but the range of power inputs and adding a volume control (Don't know what the input range is on your audio panel) might do what you want.
http://www.ramseyelectronics.com/dow...anuals/UT5.pdf
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 05-23-2010, 11:55 AM
Bevan Bevan is offline
Default Tone annunciator
Vern makes them see...
http://www.vx-aviation.com/
scroll down until you find model number AL-1A Tone annuciator
Bevan
Old 05-23-2010, 07:31 PM
cfiidon's Avatar
Default Annunciator
Now that's the ticket!
Old 05-23-2010, 07:42 PM
elippse elippse is offline
Default Warning
I have noticed that in a time of stress one of the first senses to be ignored is hearing. For the various warning signals that I have on my plane, I use a large diameter, very bright red LED that is immediately in front of me on the panel. No matter which way you are looking that light will get you attention!
