In trying to ensure that there is no contact between the exhaust pipes and either the engine mount or the cowl I decided to rotate the pipes to a better geometry. This meant redoing the rubber tube exhaust hangers. There are a bear to get off after they've been heated and in the process of repositioning the exhaust to get better access I moved it to the point where the ball joint was at its maximum travel. I didn't realize it but this allows part of the joint to gape and with surprisingly little extra (inadvertant) force, the ball joint separated.
Surprised the heck out of me!
I removed the exhaust from #1 and #3 cylinders, placed it on the floor and took the socket part of the exhaust that had become dislocated and pushed it back over the ball part.
It feels firm but I need to know whether it is junk or whether it's usable after it has been apart and back together again.
Any experience with this out there? I will call or email Vetterman on Monday, but if this is a non-issue or a BIG DEAL do not fly issue it would be good to know now.
Jeremy Constant
