Old 05-21-2010, 08:07 AM
Scott_F Scott_F is offline
Default RTV and corrosion
I need to "pin down" the conduit in my wing ribs, and since I don't have any Proseal left, I was considering other stuff I could use for this purpose. In their FAQs, Van's recommends tank sealant or RTV for this purpose. I was discussing this with a friend who was a navy maintainer for many years, and he recalled that years ago RTV was not used on AL because of corrosive properties. A quick internet search found this article http://yarchive.net/chem/silicones.html(from 1997) discussing the corrosive properties of RTV. In a nutshell, it says that silicon sealant formulas have changed over the years, and while the current stuff does release some corrosive agents (acetic acid) during curing, on AL at least, these agents only etch the surface and increase adhesion. It does mention that RTV shouldn't be used on brass or galvanized steel.
Can someone on the list who knows about this stuff help me get a warm/fuzzy that if I squirt some RTV on my wing ribs they won't corrode? Are there any places on the plane where I absolutely should NOT use RTV?
Scott Fechtig
Patuxent River, MD
RV-7 - Finish Kit
Old 05-21-2010, 08:22 AM
TSwezey TSwezey is offline
You will find red (hightemp) rtv even on certified planes these days. Not 100% sure though.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 05-21-2010, 08:25 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I have been using "Shoe Goo" for that purpose, sticks a lot better than RTV.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Used on cars - aluminum engines
There are several which say on the pkg. they are safe for aluminum because there are so many aluminum engines. I have no expertise beyond that. I used both red and black on my airplane with full OK from my A&P/IA.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 05-21-2010, 08:34 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Dow Corning 738 or Permatex Ultra Black
Dow Corning 738 should be fine - it is specifically called out by Garmin for sealing their external GPS antennas to the fuselage. Here is a quote from the data sheet for 738
A noncorrosive cure mechanism
that produces no exothermic
heat or corrosive by-products; can
be used in corrosion-sensitive
electrical and electronic
equipment (on copper and other
sensitive metals) with no adverse
effect; can be used in work areas
where sealant curing odors would
be objectionable
I personally used Permatex Ultra Black to support/glue the conduit where it passed through the holes in my wing ribs. Ultra Black is advertised by Permatex as "noncorrosive" and is used extensively on aluminum engine components in the automotive world.
I might point out though that my plane is primed 100% with AKZO epoxy primer so in my case the sealant isn't actually in contact with the aluminum anyway.
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 05-21-2010, 10:48 AM
Paul Thomas Paul Thomas is offline
I did some research a few years ago and it depends on the manufacturer. Spruce had the "good" kind.
Old 05-21-2010, 11:45 AM
az_gila's Avatar
az_gila az_gila is offline
Smile The Shoe Goo...
...looks like a good alternative.
Only Naptha and Toluene on the MDSD list - no Acetic acid -
http://ace.infotrac.net/msdsimages/e...0inc/10321.pdf
...and it does stick well....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-22-2010, 09:18 AM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default RTV usage
A&P's following Industry standard practices use Dow Corning 738 (all colors), Permatex ultra black, Permatex ultra red, and Permatex ultra copper(for exhaust ultra high Temp) routinely on aluminum surfaces with no ill effects. Hope this helps, Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
Old 05-22-2010, 11:40 AM
Thanks all for the replies. I picked up some Permatex Black on the way home yesterday and put it on this morning.
-s
Scott Fechtig
Patuxent River, MD
RV-7 - Finish Kit
