Old 02-16-2006, 06:32 PM
pboyce pboyce is offline
Default Aircraft grade carpet is expensive!
The very last thing I need to do on my RV-7A is get some aircraft-grade flame extinguishing carpet. I'm currently using some leftover house carpet which I think I probably could use as tinder at my next camping trip. That stuff burns!
So I got some samples from Douglas Interiors, which carries a full line of FAA certified carpet. I picked a nice burgundy color. Since they don't sell directly to consumers, I had my upholstery guy call them for prices. Get this: a 4' x 6' piece of burgundy wool carpet costs $387 delivered! Ouch.
So I called Abby at FlightLine interiors, who did a great job upholstering my seat cushions and she has some automotive carpet, which apparently has a higher burn rating than regular household carpet. I'm awaiting her samples.
Anyone lick this issue inexpensively?
Regards,
Paul
Old 02-16-2006, 06:52 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I used carpet from Airtex. Don't remember the price, but less than $387.00, I'm sure.
Roberta
Old 02-16-2006, 06:53 PM
Being that I'm an engineer with the world's largest carpet company, I might be able to help...
1) Buy nylon carpet. Nylon does burn if a continuous flame is applied, but has self-extinguishing characteristics. Don't buy polypropylene or polyester carpet. It burns much more easily than nylon.. (Note, wool has the best flame resistant properties, but isn't easy to find in carpet suitable for an aircraft).
2) Buy dense carpet - preferably a product developed for the commercial market. These products are designed for high wear applications such as offices, shopping malls, schools, etc. and the fibers are packed more densley. The density tends to limit surface area and airflow through the product, giving self-extinguishing properties.
3) Look for a "Class 1" fire rating. This is the top standard for readily available carpet. Anything you'd find in a school, hospital, etc. would have this rating...
4) Hint. Find a commercial carpet retailer and ask to look through their scrap bin.
Now, if you were an engineer for a carpet company, what you could do would be select yarn that matches your upholstry. Then, you'd get your friends in the product development area to run a trial of a carpet fabric you like using the yarn you selected. Finally, you'd have your friends who run the backing pilot plant to put a super-duper, fireproof, cushion back coating on the back of your carpet.
Of course, this wouldn't appear on the books anywhere...
Oh, yeah. And you'd have several sets of replacement carpet made, "just in case".
Probably not an option for most folks on the list.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-16-2006, 07:40 PM
Kyle and Roberta:
Thanks for the info. I went to the Airtex website and they have nylon carpet for $25/yard. That's a lot better than Douglas Interiors who has wool carpet for $119/yard.
I will order their sample guide for $3.
Old 02-16-2006, 08:11 PM
szicree szicree is offline
I bought some indoor/outdoor carpet from Home Depot and tested it with a lighter. Poof. I then sprayed it with some flame retardent stuff from Spruce and let it dry. Now it doesn't burn. Supposedly this stuff protects the carpet from UV as well. A lot cheaper than AV grade carpet.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 02-16-2006, 09:30 PM
aadamson's Avatar
aadamson aadamson is offline
Default Check here
http://www.amsupco.com/aviationProducts.php
Alan Adamson
Atlanta, GA
Lancair Legacy FG-6 - N60AL (fixed gear, carbon fiber, IO-550)
Lancair Legacy Builders Forum
Beta Test Blog of Vertical Power install
Old 02-17-2006, 03:37 AM
tacchi88 tacchi88 is offline
Default Carper quality
Mr. Paul,
Airtaex carpets is of poor quality in the face of the prices they ask for them. Our experience with them has been fading (even parked in a hangar), backing falling apart, and generally poor fitting.
Most of the automotive carpeting is of far superior quality and price.
Suppliers do have fire protection information, and has to comply with fire codes. FYI.
T88
RV10
w/automotive upholstery
Old 02-17-2006, 10:02 AM
Davepar's Avatar
Davepar Davepar is offline
Wow! We must have experts on this forum from just about every field. And custom making your own carpet is just plain cheating.
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 02-17-2006, 03:36 PM
Tom Maxwell Tom Maxwell is offline
Default Can You Say Group Buy
Gee Kyle, you wouldn't leave all of your good buddies out in the cold would you This sounds like an opportunity for another group buy.
Tom & Connie Maxwell
Houston, Texas
RV7A
N512TC
Old 02-17-2006, 04:51 PM
I went to Carpet One and found some commercial carpet in nylon and Class I. Of the 3 densities, I ordered the most dense one. $29 per square yard. Sure beats $119 per square yard!
She let me cut a small piece from the sample book, which I took home and tried to burn. I applied a continuous flame and and then removed the flame. It will definitely flame by itself, though reluctantly. It seemed like the polyproplyene backing is what was flaming.
My next step is to order some spray fire retardant from Spruce. Voila, homemade aviation carpet!
Thanks guys for the info.
