Old 05-19-2010, 07:19 PM
woodsideraff woodsideraff is offline
Question Operating limitations
I understand that the documents required to be carried in the airplane are:
Airworthiness Certificate
Certificate of Aircraft Registration
Operating Limitations
Weight and Balance Data
I uderstand each one except the "Operating Limitations". What excactly do I need to have?
Thanks and best regards,
RL
Old 05-19-2010, 07:33 PM
bhester's Avatar
bhester bhester is offline
Default Operating Limitations
The Operating Limitations are issued to you by the DAR that does your final inspection of your plane before it flies. They tell you what you can and can not do with your experimental plane.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 05-19-2010, 07:44 PM
Ironflight's Avatar
VAF Moderator / Line Boy
They are also PART of the airworthiness certificate (officially - not physically), so the airplane isn't technically airworthy unless they are onboard.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-19-2010, 07:47 PM
Default opertaiong limitations
Thanks for the reply. In my case, I purchased my RV8 from the builder. I just want to be sure I have the appropriate papers with me in case of a ramp check.
RL
Old 09-26-2011, 04:13 PM
Toobuilder's Avatar
Are the original signed documents required to be on board, or can you burn a copy from the .pdf found in the FAA records CD?
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 09-26-2011, 09:56 PM
RV6_flyer's Avatar
Yes a copy is acceptable. IF you lose yours, the FAA will fax you a copy from OK City.
The Sprcial Airworthness Certificate (8130-7) MUST be an Origional and CANNOT be laminated.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
