The engine is modified
Daniel,
Thanks for your comment. Yes, the plate says 25 degrees, but it is for an E2D with low compression pistons – now with high compression pistons I'm not sure it shall be the same. I have just started up the engine and I feel it has a hard run with vibrations.
Tomas Johansson
Flying RV-4, and Super Cub on floats and skis
in Northern Sweden in Skandinavia
