Originally Posted by rival_95363
Hello all,
I just purchased an rv8/a with an rv4 wing installed. The claim was that it was a stronger wing with the carry-through spar but the downside is that I can only carry 32 gallons vs. 42 gallons. I was wondering if their are any type of wing tip tanks or other types of tanks people have created or installed into the rv 4 wing to get some additional fuel.
Any advice would be great, pros and cons.
Randy B.
Randy
I don't mean for this to sound too harsh but the number one piece of advice (though too late now) is that you should have asked for advice before purchasing this airplane.
Without knowing anything about what the builder did to install the RV-4 wings, the last thing anyone here on VAF should be doing is suggesting ways to add more Fuel (load) to the airplane.
The RV-4 wing was designed for a gross weight of 1500 lbs. The RV-8 was designed for a gross weight of 1800 lbs. It is entirely possible that because of details related to the installation of a 4 wing on an 8 fuselage, that you have an airplane that may not even be capable of a 1500 lb gross weight. The only way to know would be doing an inspection and then some engineering computations on what is there.
The best advice I can think to give you at this point...respect the 1500 lb gross weight limit of the RV-4 wing, which basically makes it a single place airplane. This advice is given in the interest of your safety, and that of passengers you might consider taking with you. Seriously. You really don't know what you have, and neither does anyone else, without doing an analysis of the airplane.
P.S. It is entirely possible that the person who built this airplane is an engineer that was capable of making design changes to make the 4 wing equivalent to the 8 wing, though I doubt this is the case since he told you he used the 4 wing because it was stronger.
