Old 05-18-2010, 01:48 PM
AirbusPilot AirbusPilot is offline
Default Oil Change
Hi Folks,
I have the following question for you engines guru
My engine has almost reach 40 hours, I have been flying from 65% to 75% most of the time, 100°F ROP.
I have no oil consuption at all if I leave 7/8 on the sump, if I fill to 8/8 I lost that quart inmediatly.
Yesterday I made diferential pressure test front cylinders 80/77 and rear 80/78
May I assume that the brake-in is finished and change to Aeroshell 15W-50 (better oil for winter I guess) and also Do I have to still fly over 65% to prevent cylinder glassing or that was enought.
Waiting for you answers
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 05-18-2010, 02:31 PM
gasman gasman is offline
Fernando, I would say that you are good to go. I fill to 7/8 also for the same reason. Go have fun!!!
Old 05-18-2010, 02:51 PM
pierre smith's Avatar
Default Now the fun begins!
I agree...7 qts...it'll spit out the 8th qt Only put in 8 IF you change the filter.
Great compressions...now you can run any % of power you want.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 05-18-2010, 06:29 PM
Hi Pierre,
Thanks for answer, what about changing oil from straigh mineral to Aeroshell 15W-50???
Fernando Abasolo
Santiago Chile
VAF #2056
EAA Member 774981
Old 05-18-2010, 07:09 PM
Norman CYYJ Norman CYYJ is offline
No problems at all changing from single weight to multi-grade.
