Old 05-17-2010, 07:35 PM
GSchuld GSchuld is offline
Default House over hanger
The concept of having a home with a hanger beneath it seems to be popular in the Florida Keys. I am looking into possibly buying a one acre(200 deep/220 wide) lot in a small florida airpark and building new. Assuming I can get my hands on one of the lots directly on the grass runway, the view would be pretty nice. Having the main (and only) living space floor of the house roughly 12ft above ground level with a full length deck facing the strip sounds appealing.
I would really prefer to have a fully insulated and conditioned hanger/shop space. I have a professional wooden boatbuilding background and I own a FULL compliment of heavy duty machines that certainly don't appreciate the florida summer's high humidity (hmm...nor do I for that matter). I could forsee myself making noise fairly regularly so some level of soundproofing afforded by an insulated space could be welcome as well.
Combining the hanger and house into one structure seems as though it could be a fairly cost effective and enjoyable situation, especially if the hanger/shop/garage space(2500-3000sqft) is to be fully insulated, heated, and perhaps air conditioned. My current home has a large second story deck and we are constantly out there, as the view is pleasant. Her current home office also has a nice view which she really enjoys. Looking out onto a grass strip may be nice for her as well.
There would have to be a significant amount of fireproofing and soundproofing between the hanger/shop/garage floor and the main house level. My wife works primarily from home with some work travel mixed in. Currently, my shop is detached and 30ft from the main house and doesn't bother her a bit noise wise while she is working and I am banging away(it's fully insulated with a good amount of soundproofing). Not sure I could soundproof well enough to keep the noise level reasonable for her in an over under situation though. She does a bit of video conferencing and phone meetings so I want to respect her needs there as I'd like to stay married.
I should be getting a copy of the covenants, conditions, and restrictions for the airpark shortly to get a look see. Insurance coverages would be looked into as well.
A seperate house and hanger will probably make more sense in the end. But I was wondering if anyone around here lives in a home over hanger situation and whether they like it or not.
George
Old 05-17-2010, 08:00 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I'm not from your area, but I do know several couples who have the house over the hangar and enjoy it. Just have seperate heat & A/C systems..
L.Adamson --- RV6A
Old 05-18-2010, 05:49 AM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Take a hard look at ICF construction. Will keep the noise down/out, energy efficient, and will keep the hurricanes at bay.
There are many makers, here is one example.
http://www.nudura.com/EN/NuduraHome.aspx
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 05-18-2010, 06:05 AM
129TG 129TG is offline
Default I am a General Contractor
in Destin, FL and I too would recommend an ICF, Insulating Concrete Form type home/hangar. The benefits of building with ICF's include energy savings, fire resistance, superior structural integrity, and an ecologically sound building process, which seem to coincide with some of your criteria. I am sure that there would be a GC in your area qualified. Welcome to Florida.
Thom Grant
KDTS - Destin, FL
Old 05-18-2010, 07:19 AM
Stogie 6's Avatar
Stogie 6 Stogie 6 is offline
Default House over Hanger
Check local building codes for the size of the hanger footprint. If it is a certain size, you may be required to have a fire sprinkler system for the hanger (check fire code for this). Also there will be a separation requirement between the hanger and the home. I don't have the code book in front of me but a 2 hour separation comes to mind.
Would be glad to offer design services however...
David F. Jones, AIA
LTC, USA (RET)
Memphis, Tennessee
RV6-A - (tail sold)
Kolb Firestar KXP (sold)
Sonex Onex (N153TD) Flying
Old 05-18-2010, 08:34 AM
rich rich is offline
Default HANGAR HOMES
George,
Here is a web page with a ton of info including floorplans.
Good luck,
Rich
http://livingwithyourplane.com/
Hangar home at T67
Rich Rudolph
VAF#007
RV6A 2000 HRS.
Fort Worth,Tx.
Wright Brothers “Master Pilot” Award
Old 05-18-2010, 09:12 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation If you have to follow....
...the IBC (International Building Code) the maximum size for a "residential hangar" is 2000 sq. ft.
Over this and your building might be regarded as a commercial structure by the Fire Marshall, and that makes things trickier and more $$$. It's caused a lot of discussion with the Town Code dept.on our Airpark...
The troubles we have had have been with detached hangars on 7 acre lots - I think the Fire Marshall would flip his lid at an attached hangar over 2000 sq. ft.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-18-2010, 09:24 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Hanger/home variants
http://www.vansairforce.com/communit...autiful+hanger
Old thread, but neat stuff in there you might get some ideas out of.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-18-2010, 10:39 AM
Michael White's Avatar
George,
I design hangars for a living, and having to do a 3 hour separation between the hangar and shop/living space is not unusual. The concrete construction for the hangar that others have suggested will work well for that kind of separation, but it's not your only option. Remember that you will need to protect the hangar ceiling/home floor as well as the walls.
Also, plan on having a sprinkler system. Most building codes will require hangars to have one because you are storing "hazardous material" (avgas). The peace of mind alone would be worth it though.
As others have also said, be sure to check your HOA covenants and local building codes. They do vary from state to state, and most states have amendments to the IBC which must be followed.
Moose
VAF #136
Old 05-18-2010, 06:02 PM
Thanks for the replies. Good stuff. I have looked into ICF construction and certainly see the potential benefits. It has not been long since I finished my current house and shop(new construction). I was acting GC for both. Actually, I designed them as well. My sister is an architectural engineer(which may well come in handy again) and she worked out the minute details and final drawings. Pilings, grade beam foundation, some steel reinforcement in the main house, etc. I'm not the type to shy away from a challenge. I went with stick built (2x6 walls) on my house and shop. Old school northeast shore style, white cedar shingles and all. My better half always had a soft spot for a bold colored metal roof on a stucco faced home. That would probably match the ICF method well.
Hmm, I see you are an architect? I did the majority of my current one myself, though I have no formal architectural training. A home over hanger design would be a bit farther from my comfort zone design wise. I'd love to see any existing floorplans with this type of layout. I haven't been able to locate much so far.
George
