Old 05-17-2010, 12:19 PM
Juicegoose Juicegoose is offline
Default Proper name for nut with metal housing to hold it something?
Along the same lines as my OT bearing question I have a mounting bracket that has a hole drilled through it. There is supposed to be a little nut on the back side that has a metal housing that clips into the hole. This way when you place a bolt into the hole the nut is always there. The little metal housing is square and wraps around a square nut and little wings clip into the underside of the hole. Not sure what type of nut this is so that I can begin the process of finding a replacement. Any guesses
Old 05-17-2010, 12:24 PM
jabarr jabarr is offline
Is this what you are looking for?? http://www.aircraftspruce.com/menus/ha/nut_clip.html
Old 05-17-2010, 12:25 PM
apkp777's Avatar
apkp777 apkp777 is offline
Clipnut (nutclip)?
http://www.aircraftspruce.com/catalo...s/04-00153.php
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 05-17-2010, 12:33 PM
terrykohler terrykohler is offline
Default It sounds like...
If the application is in the front end of a car, these are typically called "Pierce" nuts, and are installed in the stamping during the forming process. The nuts are rectangular shaped and come attached together in a spool. During the stamping of, for example, a radiator support, the nut is fed onto the blank during the forming process and staked into place. They become a permanent part of the stamping. Nuts that are held in place but independent of the stamping are typically examples of "Keps" fasteners. Use of these fasteners allows the male component to be fixed without having to put a wrench on the nut.
Terry, CFI
RV-9A N323TP
Old 05-17-2010, 02:04 PM
Think i found it guys. They are called retaining nuts. heres a link to what i found. Thanks for the point in the right direction
[Bhttp://www.boltproducts.com/bolt-retainers-standard-retainers-c-215_216-l-en.html[/b]
Old 05-17-2010, 03:15 PM
drakerv drakerv is offline
If it used in instrument mounting we call them crickets.
Old 05-18-2010, 06:07 AM
nice guess but no it is used for the bed cover on my pickup truck.
Old 05-18-2010, 07:44 PM
Tbone's Avatar
Tbone Tbone is offline
They are called J-clips.
___________
Terry
RV7
XP IO360
