05-17-2010, 09:01 AM
FAB Plate Screws...acceptable?
Van's supplies four 1/4-20 (gr. 8) bolts that are used to attach the FAB mount plate to the bottom of the carb.
Instructions say to use the locking tab washers or safety wire. I prefer the safety wire, which means that I need to drill the bolt heads.
As another option, can these be used? Acceptable?
AN500-A416-10
They are fillister head 1/4-20 with drilled head.
http://www.aircraftspruce.com/catalog/hapages/an500.php
Of course using flat washer & torqued accordingly.
...and on a slightly related note: I bought the Avery bolt head / nut drill jig and I am disappointed in the results. It just drills across a point and doesn't leave much meat. Maybe I'm doing something wrong.??
Thanks for any help.
Sam Evans
RV7-A O-360 C/S
VAF#812
05-17-2010, 10:27 AM
Uneducated SWAG
It is an area where I would not experiment. I'm told that anything that gets loose in this area will get sucked through the carb to the intake valves and cylinders. There is a lot of stress there. I just replace my mounting plate that I found to be broken in my annual condition inspection. I drilled and safety wired my bolts in the original installation. It was not a big deal, probably easier with a small drill vise on a drill press.
Bob Axsom
05-17-2010, 11:47 AM
You're probably right, Bob.
No jackin' around in that area.
Guess I'll just suck it up and start drillin'!
Sam Evans
RV7-A O-360 C/S
VAF#812
05-17-2010, 11:59 AM
I used the Fillister Head Screws
AN500-A416-10
I found no reason not to use them. Have you reviewed the specs compared to Van's standard 1/4 20's Grade 8's? I think you will find the AN500's to be superior in tensile, clamping, and shear strengths. Perhaps one of our engineering buddies has that info at hand?
300 hours, no issues here.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Reason: bad spelling
05-17-2010, 12:08 PM
Weird,
I used Van's FAB kit and did not drill or buy any additional bolts for attaching it to the carb. Van's must have included pre-drilled bolts as I know I did safety wire em.....
05-17-2010, 12:10 PM
They look good to me. I am ordering 4. I am not a fan of self locking washers.
Tony Phillips
N524AP, RV 9 (tail wheel)
05-17-2010, 12:12 PM
Originally Posted by Brantel
Weird,
Sitting at home, I guess I better check with my Van's FAB kit, maybe they are drilled. I don't think they are though. I know I have them temporarily installed now with the self-locking washers that cam in the kit.
Tony Phillips
05-17-2010, 01:43 PM
When I called Van's...
...about a related issue, I asked the tech about the screws. The pick list specs 4, 1/4-20 x 1/2. He said that a 1/4-20 bolt and with drilled head wasn't (readily) available. That's why the locking tab washers are supplied. Maybe the bolts were drilled at one time. To me, they look to have the markings of grade 8 bolts.
I have an AP friend that suggested the fillister screws with drilled heads and safety wired would be fine. I just wanted other opinions or experiences.
Sam Evans
RV7-A O-360 C/S
VAF#812
05-17-2010, 01:51 PM
Follow advice on other threads to avoid cracking....
I used a large area washer, backed up with a lock washer, to help avoid cracking of the plate. I am hopeful the larger surface area might help although the source of cracking has not been conclusive. Some crack, some dont. I replaced mine at around 230 hours. Thus far, no signs of cracking on the new plate. We shall see.
The Fillister contact head area appears to be slightly smaller than the 1/4 20 bolts.
Bucker Jungmann
RV1 - Proud Pilot.
05-17-2010, 01:58 PM
Great Idea on the large washers.
I looked at the contact area also and saw what you saw. But with the large washers and lock washer and safety wire......well it sure sounds good from here.
Where's them engineers when you need'm ?? Hello?
Sam Evans
RV7-A O-360 C/S
VAF#812
