This may be obvious but it caught me unawares during the fitting process. I found out that if you don't lock the elevators in trail position when you fit the tips, you might get lucky or you might not,...
Because of the elevator push tube geometry, when you have full up elevator, it moves the aileron push tubes forward slightly at the sticks. Enough to pull them out of alignment by about 1/4 inch. If you fitted them with the elevators down, then you might be low or reversed if they were up.
Uploaded with
ImageShack.us
This is with the tooling holes lined up.
Uploaded with
ImageShack.us
Close up showing exact alighment
Uploaded with
ImageShack.us
But now tips and ailerons were absolutely flush,... until I go move the elevator to the full up position.
Not sure if this helps but it does make a difference and it can make it seem out of alignment when it's not. Just line up your ailerons and then go to the elevator and push it through while watching the ailerons. It's kind a surprising. You might not be nearly as far out as you think.
Hope this helps more than hurts :-)
Bill S
7a almost there
