Old 05-14-2010, 08:44 AM
bret's Avatar
bret bret is offline
Default Rudder construction question
I am ready for final assembly of the rudder skins and doing a dry run of the R-909 tip. What have you guys done with the trailing edge fit, should I trim the top of edge R-916 before riveting, or the fiberglass of R-909 that goes into this area afterwords?
Old 05-14-2010, 10:19 AM
FresnoR's Avatar
FresnoR FresnoR is offline
I would think it best to leave all the fiberglass work until after you are finished with the rudder.
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
