Old 05-12-2010, 06:28 AM
db8's Avatar
db8 db8 is offline
Default EFIS/EIS input limitations parameters
I have installed my dual GRT HXs. I am building an 8 (tail dragger) with an IO-360 180HP engine. I was wondering if anybody has the parameters selected in the set-up menus (for plane and engine) that are similar to mine?
My plan is to set the EIS as the no kidding red light engine warnings (ie real attention getter), and am going to use the EFIS numbers slightly less than those for its warnings.
As far as the plane goes, I know this info varies slightly from plane to plane, but I'm looking for a good start. I can look (and have) at the numbers on Van's for Vne, Vx, Vy, Max cruise, stall w/flaps, etc, etc, but it's reassuring to get these from others too (get a good average).
They might be listed in someone's POH, computer or handbook? If someone might have this info or be able to direct me to a site (or fax it), it would be appreciated. Thanks. Dave
Dave Buntin
http://i55.tinypic.com/iny6qa.jpg RV-8, N 130YS, BOYS & TOYS
[size="1"][color="Blue"]
