Old 05-11-2010, 06:54 AM
SmittysRV's Avatar
SmittysRV SmittysRV is offline
Default Static Kit
Before I post my question, I want say how grateful I am for Doug Reeves website. I don't know how I could have gotten this far on my RV without consulting this forum and reading the inspiring stories on the home page. Doug, You ARE the man!
Now, for my question. I've started on Van's static kit. Am I supposed to use these little clear plastic dodads on all the ends of the "T"? It seems that the clear rubber tube fits tightly on the "T" without the dodads (technical term). Also, is this kit OK to use with the Dynon?
Smitty
Old 05-11-2010, 07:27 AM
Ironflight's Avatar
VAF Moderator / Line Boy
The little "Doodads" go inside the ends of the Nylon tubing after you put the Nylock nut and ferule on. You're right that the clear tubing goes directly onto the barb'ed "T". I am not sure how they want you to connect the clear tubing to the Nylon tubing.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-11-2010, 07:42 AM
flion's Avatar
flion flion is offline
The clear tubing goes from pop-rivet/static port to the t-fitting. The nylon line runs from the t-fitting forward. I was concerned about the clear tubing but it seems to be working fine in the -6A; nevertheless, I am exploring alternatives for the -10. I ended up not using the plastic ferrules at all because the connectors I got had their own.
EAA Technical Counselor #5357
Old 05-11-2010, 07:53 AM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Upgrade
I bought and used the safe air kit. I got their kit and the dynon angle of attack kit, alt air kit from Avery. Very simple, easy to use and not that expensive. Seemed like a good place to blow a few bucks but feel it was a worthwhile improvement.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
