Old 05-11-2010, 06:33 AM
DocThrock DocThrock is offline
Default GRT Hall Effect Sensor for AMPs broken
The plastic part that holds the wires came out of the green "magnet" part of my current sensor. Can I just epoxy the plastic part back into the magnet or ring part and it will be OK? Looks like the two parts were just glued together anyway....
Thanks!
Old 05-11-2010, 08:45 AM
Tom Moore Tom Moore is offline
Same thing happened to me. I just epoxied it back together. Be sure to get the wires fitted back in their original position or else it will not work. The diagram that came with the unit provides enough info to help with this. If I remember right, it?s the green wire on top and the wiring harness should exit the donut in the same direction as the arrow.
