05-11-2010, 12:37 AM
Correct Adel clamps for engine compartment?
OK, I know the engine mount tubes are 3/4", so I need MS21919W(XX)-12s.
But...what "XX" is recommended for use in the engine compartment?
From Genuine Aircraft Hardware, I see 3 kinds of bands and 5 kinds of cushion!
My guess, and it's just that, is an MS21919-WCJ
C - Corrosion Resistant Steel band
J - Fluorsilicone cushion
That looks like the only combination that is a) temp resistant to 400 deg., and b) resistant to petroleum-based fluids.
But those dudes are over $3 *each*.
What are your thoughts? What are people using in the engine compartment?
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
05-11-2010, 01:17 AM
Come by the shop...I have a 55 gallon drum of surplus adels your welcome to scrounge through. We also carry stainless ones, but I do not know what the rubber is.
Mike Sumner
Castaic, Ca
05-11-2010, 08:09 AM
Ace Hardware
Your local aircraft supply store
05-11-2010, 09:35 AM
Everything you ever wanted to know and more...
05-11-2010, 11:17 AM
Hmmm....thanks for the responses, guys, but none of them answered my question (but Mike, I'll be by to scrounge through your bin  ).
I have the specs, courtesy of Gen-aircraft-hw, but I was asking...what are people using? Is it necessary to use the ones for higher temp (400 deg) vs. the 212 deg ones? etc.
Again...what are people using in the engine compartment? What is *acceptable* for use according to FAA, etc.?
Santa Clarita, CA
#8,000
05-11-2010, 04:02 PM
My certified Grumman...
...uses the DG type, including a critical one holding the mixture cable outer sleeve in place on a carb bracket.
The only exception I can think of is the spark plug wires clamped to the cylinder heads, and they use a white insulation and a special Champion part number.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
05-12-2010, 12:10 AM
Thanks for the data point, Gil.
Just don't want to get all the way done and have someone (like the DAR) say "hey, you can't use those there, they have to be [xxxx] type"
Guess I'll order up some WDGs and use them until/unless I hear or learn of any other requirement.
Santa Clarita, CA
#8,000
