Old 05-10-2010, 04:44 PM
Fearless's Avatar
Fearless Fearless is offline
Default How to Wire - Vans Flap Switch ?
Would someone be kind enough to show me how to wire the tabs on the standard Vans flap switch that comes with a 9A. It has 6 tabs on the back.
It is a (ON) - OFF - (ON) switch. I do have the AeroElectric manual but I probably need a copy of Electrical Airplane Wiring for Dummies instead.
A diagram or description of what wires go to which tab would be nice.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
Old 05-10-2010, 04:53 PM
Brantel's Avatar
Brantel Brantel is offline
/1 2\
|3 4|
\5 6/
Connect the - power to 5 and 2
Connect the + power to 6 and 1
Connect the flap motor leads to 3 and 4
If the motor runs opposite what you want you can either change power leads or switch 3 and 4...
an alternative is:
Connect the - power to 3
Connect the + power to 4
Connect one leg of the flap motor to 5 and 2
Connect the other leg of the flap motor to 6 and 1
This does the same thing.....
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 05-10-2010, 06:39 PM
MCA's Avatar
MCA MCA is offline
Our VP-50 wiring diagram here shows how to wire it. Just focus on the flap switch part.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 05-11-2010, 04:56 AM
Fearless's Avatar
Default Worth a thousand words
Thanks guys
That did it for me - I think it was the jumper part that was getting me.
I hope to take the EAA Sportair Electrical class once one gets closer to my home. I am starting to use the tools I got from Stein (shameless plug). Now I just need to learn how to use them correctly.
Mike
RV-9A Based K6I2
Old 05-11-2010, 10:45 AM
LarryT LarryT is offline
Default Wiring for Dummies...
..is too advanced for me. I need "Aircraft wiring for Cretons."
LarryT
Old 05-12-2010, 11:06 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default switch wiring
Here's an image of wiring the flap switch from one of AeroElectric's schematics.
[/IMG]
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 09-16-2010, 11:36 AM
rblackley's Avatar
rblackley rblackley is offline
Default Flap potentiometer
can flap position be seen out of slider canopy while flying?
Old 09-16-2010, 11:44 AM
MCA's Avatar
MCA MCA is offline
Yes........
Marc Ausman
Fearless's Avatar
You can put some markings on the wings at the various flap positions (which I intend to do) put not sure how visable they would be at night. The CFI I did some transition training used this method for flap deployment.
Mike
RV-9A Based K6I2
Old 09-16-2010, 08:30 PM
The diagram for wiring this is also on one of the Van's OP drawings for their electrical harness.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
