during Aero Masters thesis worked this problem in a wind tunnel with all sorts of various shaped pitot tubes.
BLUF: between +-15 deg of AOA the error is inside that of your instruments resolution (particularly since Ps, static error, will vary more for changes of AOA). Outside +- 15 deg the error rises almost parabolically with angle.
I haven't flown my RV8 yet so I can't tell you what the normal range of AOA is but someone should be able to tell us, but I doubt it gets much if at all higher than 15 or so. Take care to understand how that AOA is measured before you use the data to set your PITOT. Many are units of AOA and not degrees of AOA, meaning it is arbitrary and relative to the angle of the probe and not to the cord line of the wing.
One of the best PITOT tubes I tested had a swiveling tip that would adjust to AOA and Beta (sideslip angle). Its big, ugly, and required maintenance. No thanks.
Im in post op surgery so if what I wrote makes no sense blame the doctor!
