Old 02-15-2006, 12:24 PM
Default Aircraft Spruce - Wrong Part
When you try to order a sealing O-ring for the piston in a 500x5 wheel brake Aircraft Spruce is supplying an AN6227B-23 instead of the required MS28775-218. The major difference is cross section dimension. The AN part is 1/8" (0.125") and the MS part is 0.139". The smaller part will leak. I have relayed the information to them.
Bob Axsom
Old 02-16-2006, 08:52 PM
Default Van has the right part
Van's catalog has the correct part listed under Hardware Misc. MS28775-218.
Bob Axsom
