Oil - time between changes and grades
I have a few general questions about aviation oil:
1. My engine was rebuilt in 1996 at Lycoming and now has about 1400 hours. I have been wondering for some time about the 50 hours between oil changes that Lycoming recommends. Is there any data that says you must change the oil and filter at 50 hours or your engine will seize up, or is it just a Lycoming-Aeroshell agreement to be very conservative and increase profits by selling all of us $36 of oil every 50 hours, when they probably know that we could go longer than that between changes. My last oil analysis from Blackstone showed everything normal and nothing out of range. Is there any recorded correlation between oil age and engine damage? Usually at 50 hours I have already added about 3+ quarts, so the majority of the oil only has about 10-25 hours of use. Does this mean that I can go a few more hours? I know that its not a large expense in the realm of aircraft costs, but is it really necessary? What is the consensus about time between changes?
2. My petroleum vendor has many varieties of aircraft oil ranging from $40-75 per case. I use the expensive oil, Aeroshell 15W-50, which is a multi-grade semi-synthetic oil. The less expensive oil was single grade and non-synthetic. I live in a warm climate, do I need multi-grade or synthetic oil? Who is using the $40 a case oil and have you ever had problems using it?
Mike Shook, RV-9A, Dynon HDX,
CPI-2 Ignition, Catto Prop, EAA 124
