Originally Posted by Greg Arehart
That mixture (no pun intended) doesn't seem right somehow. The cylinders are way too cool for oil temps that high. Any chance your oil cooler line is blocked? Vernatherm not working?
Seems a head scratcher to me.
greg
Or the CHT temp values aren't valid. With temp #'s that don't jive with what would be typical for RV's, the first thing I would do is try and verify the #'s. Maybe you oil temp has an error to the high side.
If the temps end up being valid, then I would try and find out why, instead of doing a cooling mod that (as far as I am aware) know one ever has to do.
