05-06-2006, 06:26 AM
Originally Posted by Ironflight
You can't undrill a hole...unless you're working in fiberglass!!
then....
Dry Micro is your BEST friend!
Paul
Paul,
That isn't ALWAYS true. All the 1/16" and thicker angle on our RV kits is made from 6061-T6. This is a weldable alloy (unlike 2024-T3) I wanted to kill myself when I countersunk the WRONG side of a line of holes on one of my sub longerons a few years ago. Then I remembered that 6061 could be welded. I work in a warehouse bay (no room in the condo). My landlord is a top notch machinist and welder. He fixed my screw up in 2 minutes. A few minutes more with the belt sander and ScotchBrite disc, and all was well again. Talk about dodging a bullet!
Charlie Kuss
08-18-2006, 04:10 AM
Pick up your air hose
1. Always pick up your air hose when not being used. Otherwise, you might get sick of tripping over it and grab it and flick it out of the way. Only you might forget that it had a dirty great big brass air connector on the end of it, and it flicked a lot farther than you could ever believe... and smack your missus (who was kindly helping you de-burr) right across her eye brow.
2. Never, never, never yell at your missus to stop bleeding all over your shiny new airplane.
3. Pay much closer attention to the quality of the dog food you feed your mut. You might have to share it with him.
Phil North
RV-7 Wings
ZK-REB reserved
Te Awamutu, New Zealand
08-18-2006, 08:02 AM
Whew - close one!
I thought you were going to say it hit and dented one of your wing or fuselage skins!!
Thomas
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
09-28-2006, 11:44 AM
1. Never assume you know the next step in the construction sequence.
2. If you disregard step 1, pay close attention to the difficulty of what you are attempting. If it doesn't seem right, or it's way more difficult than it should be, stop. And if you can stop before you drill or cut anything, do so. Then check the plans, the instructions, correlate the instructions to the plans, then check the work.
3. Keep in mind at all times that cutting tools and drills have no 'undo' button.
09-28-2006, 11:56 AM
Blood
Phil North
RV-7 Wings
ZK-REB reserved
No, yelling is not needed... this is one of the advantages of metal planes... the blood cleans off easily with solvents.
Now if you were building a wooden plane.... then the rule is "don't bleed on the work"....
Gil in Tucson - who built a 42 ft span wooden sailplane...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
09-28-2006, 09:57 PM
Quiet
Phil, you kept that quiet! I wondered why I hadn't seen her around the last couple of times I came over :-) I've yelled at Jackie a couple of times; I'm trying not to do it 'cos I hate having to beg to get her to come back and finish whatever we were doing at the time! Few more days will see this right wing closed up I reckon...
10-13-2006, 11:13 AM
back riveting
When back riveting, don't get so wrapped up in all the process of loading rivets, taping them in place, getting out the back rivet set, setting up the gun, etc that you forget to place the SECOND piece to be riveted onto the taped-in-place-rivets before setting the rivets. I've done this more than once.
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
10-13-2006, 11:18 AM
Senior Curmudgeon
(BJ 1B)Duster by any chance??
Mike
10-13-2006, 03:33 PM
An RV is not made of metal as is popularly thought, it is actually made of blood, sweat, and curses.
10-13-2006, 06:01 PM
Follow-up to Brian's Single Piece Riveting Tip
When you do forget to place the second piece - your rivets will be the best ever.
