Old 12-30-2016, 05:38 PM
dcurrier dcurrier is offline
Default Deburring the inside of flanges with the speed deburring tool
So, I was struggling to figure out how to use the speed deburring tool from Aircraft Spruce on the inside flanges of ribs and spar channels. It is difficult to keep a perpendicular angle in tight spaces. Without the perpendicular angle you risk getting an oblong hole instead of a circular one. Came up with the idea of installing the bit into the end of the 90 degree angle attachment (which comes in the Aircraft Spruce RV Tool Kit as well) and hand turning the shafts that would otherwise be inserted into the air drill. This works out really well. Dunno if someone else already posted this idea or not, but it seemed too "Eureka!" not to share.
Damien Currier
Maricopa, AZ
RV-8 Very Slow Build In Progress
Empennage kit 99% done and placed in long term storage
Wing kit building in progress
Saving for fuselage kit
N163RV (Reserved)
My Build Log
2020 Dues Paid
Old 12-30-2016, 06:00 PM
wirejock's Avatar
wirejock wirejock is offline
Default Deburring
Similar, but my tip ran in Kitplanes.
Run a 1/4-28 die over the shaft of the 90 degree adapter. Screw the adapter into the speed debur handle. Now you have a 90 degree debur speed tool.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 03-16-2017, 06:08 PM
wirejock's Avatar
Default Builder's Checklist
We all know how important checklists are before, during and after flights but consider using one for building as well. Start it early. I use one and it's really handy.
All those little (or big) things you have to postpone for whatever reason should be added to the list. Keep it handy in the shop and scratch items off as they get done. You'll sleep better.
Mine is a spreadsheet. I print the latest and write notes on it like date of completion or new items. When I update my builder log, it gets updated too and a new one printed.
Anything works from a chalkboard to a big poster board or spreadsheet. The point is don't assume you can remember all those little things. There's so many of them.
Larry Larson
Estes Park, CO
Disclaimer
Old 07-24-2017, 10:44 PM
PilotjohnS PilotjohnS is offline
Default Wing skin countersinking
When countersinking the gazillion wing spar rivet holes, dont wear socks with no shoes. And if you do, don't wash the socks with your wife's bra.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 5% in work
Firewall Forward 5% in work
www.pilotjohnsrv9.blogspot.com
Old 02-02-2019, 10:39 AM
hardegg hardegg is offline
Originally Posted by DeltaRomeo View Post
...idea emailed to me by Terry Ruprecht. Great idea for a thread
RV Beginner Builder Hint #1:
When a small shiny tool rolls out of place on the work table, do NOT reach over lightning-like and move it back by the shiny end. It may be a soldering iron.
RV Beginner Builder Hint #2:
Unusual smells in the shop may include burning skin.
Adendum to #1: don't worry about blowing on the glowing end to cool it off - if your not paying close attention - you might smack yourself in the lip.
it leaves a nasty burn.
Old 02-02-2019, 07:29 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Cool #154....
May the funniest thing I?ve ever read on this site.
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2020 VAF contributor
Old 04-26-2019, 10:54 AM
vernh59 vernh59 is offline
If your glove is between the part and the bucking bar, your finger probably is too!
Fly safe,
Vern
Ozark, Al
RV-7 Build No. 71139
Empennage Complete, Wings on hand
Starting Fuselage 11/15/19
https://eaabuilderslog.org?s=lhead
Exempt but gladly donating!
Old 04-26-2019, 12:38 PM
DanH's Avatar
DanH DanH is offline
Same for the jeans and tee shirt you were wearing while grinding fiberglass...
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-07-2020, 10:55 PM
Jason2020 Jason2020 is offline
Default Why is it so hard.
Deep thought #1
26 inches on a tape measure looks a lot like 29 inches when looking at the tape upside down. Way different results though!
Old 04-08-2020, 07:22 AM
PaulvS's Avatar
PaulvS PaulvS is offline
Default Sides of the rule
-> One side of the rule is divided into 1/8ths. -> The other side is divided into 1/10ths.
Note which side you're on.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my low-n-slow Aeroprakt A-22 and the aero club's RV-9A while I build
