08-02-2011, 12:06 PM
Sorry, it's a little big, but I love this advice!
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
08-03-2011, 11:54 AM
Drilling Tips
I am sure that tips like this one have been mentioned before. I have found that when drilling holes, I really like the final size to be done with a reamer. I got this advice from Noel Simmons about the rivet holes but I think it is doubly important to have clean holes when it comes to bolting parts on like the tail feathers. There are several places where the holes will be drilled though some fairly thick material, as Noel explained the drill bit has a tendency to leave a spiral cut mark on the sides of the hole as it goes through.
Using a reamer does a couple of things: 1. It cleans up the hole and makes for a nice finish fit for the bolts and 2. If the hole is a pickup hole, in other words drilling into another hole that was scribed and then back drilled, it will help alignment of the assembly.
There is no need to buy a complete set of reamers, the most common ones that I have used so far are the #40, #30 (for rivet holes) and 3/16" for -3 AN bolts, 1/4" for -4 AN bolts and 5/16" for -5 AN bolts. I would also have a set of numbered and fractional drill bits handy, it has worked for me to drill the holes a couple of sizes under the final size and then final ream, this also helps if the hole was drilled slightly crooked, it leaves a little material for the reamer to center itself.
I also use Boelube for cutter lubrication, I have had really good luck with the 4 oz jar of this stuff, its a little spendy but it really does make the cutters last longer.
Another thing, Starrett.com has some really nice reference information about drilling and tapping and you can order the reference cards from them for free. I order some for my A&P students every year and it's really invaluable materials to have in your toolbox.
Karl Kruger
RV-7A N915JB
______ | ______
___\__(X)__/___
....... o/ \o
"You can have 5000 hours in fast jets and still
kill yourself in a Cessna trying to impress your Grandma."
08-31-2011, 04:15 PM
Rivet hole alignment tool.
When you break your 6 inch clearance drill bits, Use the un fluted shank, put a dowel handle on one end and a smooth taper on the other and they make the best rivet hole alignment tool because they are the right size for the hole.
11-08-2011, 03:11 PM
Originally Posted by Karl.Kruger
If you decide to skip a step because you think it might be a better idea to wait until later in the build process, make a note of it, otherwise you will spend a fair amount of time wondering "well now...why didn't I put those four rivets in?"
Am finding this out the hard way...3 years away from working on the project during a move results in a lot of time spent going back and forth from the fuselage to the manual to the bench full of parts to the plans and back again.
AAAARRRGH! Hopefully it won't be much longer before I am once again oriented and cutting metal.
11-08-2011, 06:43 PM
Changing bits
If you are going to change drill bits in your souix with your hand, where safety goggles or do it really slow. I slung the drill bits out a few times at lightning speed and would easily put your eye out
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
06-30-2012, 03:29 PM
Tip #1001:
Polish wheels are abbrasive on the skin. Very abbrasive
Miguel Vidal
EAA #1133587
RV-8 SB Wings in Monterrey, Mexico
N511MV Registered
MyKitLog
07-01-2012, 09:28 PM
There's no point getting good sound for your shop since you can't hear it over the air compressor anyway.
Dave
07-01-2012, 11:26 PM
The sagest advice ever:
"Make haste slowly."
Pretty much every mistake I've made was because I was working too quickly, moving too quickly, or failing to think about what I was about to do/move/work on. (Applies to just about everything, including my regular job  ).
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
07-02-2012, 08:22 AM
Finger clamps
Don't use your fingers as clamps. Getting
bits of metal out of deep tissue takes a long time for
your body to eject. Oh and a sharper bit I think
may do less damage!
Al Girard, Newport, RI
N339AG
RV-9
07-15-2012, 08:38 PM
If your construction manual or builder's log does not have any of the following: blood, oil, grease, metal shavings, ink, beer, tears, sweat, or such marks and/or stains within its pages, you are most likely doing something wrong, and probably not building an airplane. Recheck/redo your work accordingly.
Miguel Vidal
EAA #1133587
N511MV Registered
MyKitLog
