Old 03-28-2010, 02:11 AM
chinch chinch is offline
Originally Posted by Grass1400 View Post
Or, don't let eight months go by without working on my project.
Or 11 years.....
Old 04-03-2010, 01:21 PM
eric_marsh's Avatar
eric_marsh eric_marsh is offline
Originally Posted by Davepar View Post
After you make two mistakes in a row, take a breather. Otherwise you're likely to make a third.
A variant on this is:
When you start to feel tired it's time to take a break.
Old 12-18-2010, 06:14 AM
N223JH N223JH is offline
Default Shop Rules
Unless I missed it, no tips yet on this thread about Miller Time. Here's what is strictly enforced here at the Southern Engineering Corporation Annex-in-the- Hills.
Drill Press, Scotchbrite Wheel: 8 hours bottle to "on" switch
All power tools, firearms: 0 beers
Hand tools: 1 beer
Broom & dustpan: 2 beers
Light switch "off", shop locked: 3+beers
Rules apply to builder, helpers, spectators.
Jim in South Texas
RV6A 223JH
RV12 N233TX
Old 12-18-2010, 09:55 AM
aerhed aerhed is offline
#79 If your local Jehovah's witness is a pilot DO NOT show him your plane. He will fill your shop with "Watchtowers" . Of course you can use them for masking paper later.
Actual repeat offender.
Old 01-12-2011, 05:13 PM
If you're going to weld something, try to choose something that doesn't lose strength when welded, like 6061-T6 does. It loses roughly about half its strength when welded.
Old 01-12-2011, 09:04 PM
klovning's Avatar
klovning klovning is offline
Default Breathe
1.)
If you run into a build problem (e.g. a hole in the control horn on the right elevator and the bearing bushing don't quite line up perfect) take a day or 2 to think about it.
The answer will often come to you while doing something else. (in this case an appendectomy) Adjusting the bearing rods on the right elevator 2 turns lined everything up perfectly...
2.)
Ask the forum - this commnity has pulled my bacon out of the fire before.
3.)
It's your plane do it the way you want to.
4.)
Other's may think you're crazy building a plane in your garage... ignore them
5.)
Make friends with your neighbor
Jason Klovning
RV8A fuse
Platteville, WI
Old 06-29-2011, 01:02 AM
DogTrick's Avatar
DogTrick DogTrick is offline
Default Cave Politic
Mike?s first rule of unintended consequences: SO's shoe expenditures rise in direct proportion to the number of tools you admit to buying.
RV-8 in progress
Old 06-29-2011, 07:09 AM
airguy's Avatar
airguy airguy is offline
RV-8 in progress
Consider yourself lucky. Mine decided we needed a pool.
Old 06-29-2011, 11:43 AM
sstellarv10 sstellarv10 is offline
If all I have to deal with is shoes and clothes, I don't think she will exceed what I've spent so far
Steve Stella
#40654 Finishing
N521RV reserved
Old 07-31-2011, 02:00 PM
Karl.Kruger's Avatar
Karl.Kruger Karl.Kruger is offline
If you decide to skip a step because you think it might be a better idea to wait until later in the build process, make a note of it, otherwise you will spend a fair amount of time wondering "well now...why didn't I put those four rivets in?"
Karl Kruger
RV-7A N915JB
______ | ______
___\__(X)__/___
....... o/ \o
"You can have 5000 hours in fast jets and still
kill yourself in a Cessna trying to impress your Grandma."
