  #41
Old 06-08-2015, 06:29 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
What Bob said,-------------- I had been wondering the same thing.
There is no way that my seats would come out as factory built.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-08-2015, 06:34 PM
So I guess I should have asked, when did you get the finish kit (seats). My builder number is 40745, finish kit in mid 2009 if I recall correctly. My seats do not come out with the flap torque tube cover in place. I've tried!
Old 06-08-2015, 06:42 PM
Auburntsts's Avatar
Late Fall 2010
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 12-26-2015, 10:29 AM
Plummit's Avatar
Plummit Plummit is online now
I would sure like to see a pic of the modified UMHW. I have my pilot's seat out now and and both seat stops loose. It would be easy to make the changes.
thanks
~Marc
RV-10
N814RV
2020 Donation Made
Old 12-26-2015, 11:00 AM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
It's pretty easy, I just did it the other day. Just chop about 3/4" off of the plastic guide material at the front of the rail and it'll easily install and come out.
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Chief
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
Race Coordinator STOL Drag coming to Reno, 2019
"so I got that going for me... which is nice."
Old 12-26-2015, 05:08 PM
aerhed aerhed is offline
Y'all should do the "Stamper mod" while you're at it. Pull the two 1/4 inch flush bolts out of the rear stop, screw the rail in with a couple four screws and drill down through the seat cover. There's just enough room to miss the spar (don't plunge it) and install -4 nutplates in the seat cover. You'll never have to unbolt the T- handle again.
Actual repeat offender.
Old 12-27-2015, 06:03 AM
GregMac GregMac is offline
Default Looking for seat rail mod
Ron, Just do a search on Vans Airforce RV10 forum for "Looking for seat rail mod" just about everything known to man about RV10 front seat removal is there. Cheers from Western Australia
Old 12-27-2015, 08:11 AM
Plummit's Avatar
The only thing that comes up with that search term is this thread!
regards
-Marc
RV-10
N814RV
2020 Donation Made
Old 12-27-2015, 09:32 AM
stamper stamper is offline
I'll be back to work on my 10 next week after not touching it for 10 months. Pretty excited to finish it up. I'll post some pictures of the mod aerhed was talking about. I did the nut plates on the back of the T-handle and it still took to long to take the seats out so I ended up figuring out the nut plate on the bottom of the cover. It leterally takes 2 minutes to pull a seat. Takes longer to go to the tool box and get the socket then it does to pull the seats.
2016 dues paid
RV10 Started Jan 2013
DAR sign off April 23rd 2016
PA-18
PA-46
Cessna 172 and T182RG
RV-10
Old 12-30-2015, 09:39 PM
bwestfall bwestfall is offline
Default stripped screws
I would recommend doing this mod before installing the seat rails for the second or third last time . The 14 or so flush head AN screws in the seat rails are a PIA and prone to stripping.
Ben Westfall
RV-10 (phase 1 flight testing)
Coeur d'Alene, ID
