Originally Posted by G-force
Mil spec. is 1.3 min. diameter, Vans calls out 1.5 dia. I believe the aluminum gauges are at 1.5 I like to set them so they fit in the 1.5 hole with a very tiny amount of slop. If it doesnt, and the height is still good, that good enough for me as well. What we really need is a go/nogo gauge with a 1.3 dia and 1.5 dia hole. For the record:
3/32 rivet: 1.3d= .122" and 1.5d= .147"
1/8 rivet: 1.3d= .163" and 1.5d= .188
Numbers rounded off to the nearest thousandth.
3/32 rivet: 1.3 d = 0.122" and
1.5 d = 0.141"
1/8 rivet: 1.3 d = 0.163" and 1.5 d = 0.188"
Only 0.006 difference, but the 0.147 is probably closer to your Avery gauge hole size.
However, 0.122" and 0.163" are the really critical minimum diameter dimensions.
Note that there is NO maximum shop head diameter, so a go/no go gauge is not really applicable here.
If it's bigger than the minimum, and not too flat - minimum height of 0.038" and 0.050" - you are good to go.
You can check for maximum height, but I believe that is a physical clearance issue, rather than a rivet strength issue.
PS .... I'd like to give Brian Yablon credit for all of the on-line rivet spec. drawings - he created them in the 90's (pre-HTML editors) and they have been copied absolutely everywhere since then. Both links above use his drawings...
I don't know where he is now...
