Did you put a direct reading _mechanical_ gauge on it? I have had a high OP reading, fretted about it for weeks and finally determined it was a bad sender. I will go so far as to say high OP is usually the sender, the gauge or electrical interference in a non-shielded wire from the sender to gauge.
The OP system is stone simple: the OP relief ball moves against a spring to normalize pressure. The only thing that can make the OP go high is a jammed relief ball or cold oil, AFAIK. Even if there was debris in the OP passages downstream of the relief point, the ball would still relieve to give a normal pressure at the sender port.
BTW, I have also had low OP caused by a piece of plastic (oil container ring?) jamming the relief ball open. That was real. But high OP, it almost can't happen at normal temperatures.
-Kent
