  #21
Old 04-04-2011, 09:16 PM
flyingbeaver26's Avatar
flyingbeaver26 flyingbeaver26 is offline
Here is what I did. I bought a steel contuit junction penetration at Home depot and fit it to the firewall. They sell them in 1/4" diameter increments. I added a 2nd nut to act as a jam-nut. On the engine side I added about 5" of firesleeve with a steel band to keep it tight. I also added the set screw back inside the conduit part to prevent the steel band from slipping off. I have to give credit to my EAA tech rep Deene for the idea. I'm able to fit all three control cables plus my EI coaxials though this point. I'm not flying yet, but it looks to be a good solution thus far.
-Brad
Old 04-05-2011, 05:11 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Originally Posted by flyingbeaver26 View Post
Here is what I did. I bought a steel contuit junction penetration at Home depot and fit it to the firewall. -Brad
Brad,
Great minds think alike! I did the same thing to get all my electrical connections through the firewall. The hole is big enough to get the Lightspeed ignition cables through without having to disassemble the connectors.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 04-07-2011, 07:51 PM
tonyjohnson tonyjohnson is offline
Default most excellent idea
Beaver and Ron,
Thanks for that great idea.
It turns out that I have a box of 50 of those connectors left over from the rennovation of my home. I did not even have to go to home depot.
Tony Johnson
RV8A "Badboy" N12TJ
Treasure Island Florida
Old 07-27-2012, 09:53 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Default Steel eyeball bushings from ACS
Can anyone tell me why the steel eyeball pass throughs have a max hole size of .26. Is there any reason they cannot be drilled out to fit the 3/8 throttle / mixture cables that Vans supplies??
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 07-29-2012, 09:48 PM
koda2 koda2 is offline
Default Drilling out steel eyeball grommets
Yes you can drill out the grommets. But it is a PITA.
But there is also a limit to the size because of the way the back of the eyeball portion is designed:
It took making a jig for me. Even then, this one is off a little bit.
I talked to the owner of the company when I was struggling with mine. He was a really nice guy and offered to try to do some special stuff if I couldn't get it to work but it ended up not being necessary.
You can do the Dan Horton trick for pass thrus but I had no luck getting stainless steel tubing bent.
Dave A.
6A build
Old 07-29-2012, 10:12 PM
Ron RV8's Avatar
Thanks Dave
I ended up using conduit box connectors with fire sleeve and it worked out fairly well...
Ron Townson
