Old 05-07-2010, 01:56 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default GRT Updating
I lost the thumbdrive used to update my GRT EFIS 1 and GRT website says to "Use the one supplied you", and that others may not work. Sure enough, I bought a Lexar and GRT does not recognize it.
I emailed GRT yesterday for advice but no joy so far, they must be busy... Anybody have an inkling of a particular thumbdrive I could purchase that would be compatible? I would love to get the update done during the weekend.
Anyone?
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 05-07-2010, 02:53 PM
Radomir's Avatar
Radomir Radomir is offline
I used a couple different Kingston DataTraveler sticks and they all worked (largest was 8Gb that I tried)
Radomir
RV-7A sold
Old 05-07-2010, 02:55 PM
Kahuna's Avatar
Kahuna Kahuna is offline
Ive used a kingston 4gb, sony 8gb, and a few others Ive had laying around.
Not sure if their drivers change by model. Mine were horizon 1 and HHX models.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 05-07-2010, 03:28 PM
bcondrey bcondrey is offline
The olders Horizons are a bit finicky about the USB stick - give Sandy a call and she can fix you up.
Bob
RV-10 N442PM
Old 05-07-2010, 04:06 PM
Bavafa Bavafa is offline
I have four different brands all work OK, but there are some that won't work. If you are in a hury, I am sure purchasing a new one has a good chance of working.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 05-07-2010, 04:19 PM
scard's Avatar
scard scard is offline
I would say, don't bug Sandy about USB flash storage unless there is a major failure of the efis. There are some that don't work, and many that do. It doesn't have to be very big at all, just stop at any store on the way to the airport and get another one to try.
Scott Card
CMW E-Lift
Old 05-07-2010, 05:47 PM
Default In the meantime...
I picked up a 2GB Kingston at Fry's for $10, loaded it up and will see if she works tomorrow. Has anyone put the Terrain feature into a WS? How did it work?
Thanks for the responses,
Jerry Cochran
Sherwood, Oregon
Mark Twain
Old 05-07-2010, 06:05 PM
nucleus nucleus is offline
Lightbulb Needs FAT32 Formatting
This likely not be your issue, but they need FAT32 formatting, default on Windoze but not Macs...
Hans
Dr. Hans Conser
Bozeman Chiropractor
RV-6A 195 Hours, up for sale soon?
Old 05-07-2010, 07:03 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Hans
Friend of mine just went through this today.
This was a AFS, not GRT, but the FAT32 issue was the same.
Also, they told him to format the stick every time before he does a download of new info.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
