05-07-2010, 09:19 AM
Carb vent cover flange
Just noticed this on my carb. Bowl vent cover (thanks for the correction Brantel) is not flush with the mating surface. The fasteners came torqued. I am wondering if anyone else has a similar condition. This carb came from AERO and is an overhauled unit. The gap between the flange and the carb doesn't look right. There is a soft gasket which is pretty much useless. Perhaps this is normal?
[IMG]  [/IMG]
Tony Phillips
N524AP, RV 9 (tail wheel)
Reason: Terminology correction
05-07-2010, 09:40 AM
That is the carb bowl vent cover not the accelerator pump.
05-07-2010, 10:00 AM
Thanks, I will up date my thread accordingly.
Tony Phillips
05-07-2010, 10:27 AM
I'll bet that if you sectioned that assembly, it would look something like this:
If so, a bit of gapping might be OK, so long as the rim of the bowl is pressed tightly against the gasket.
05-07-2010, 10:30 AM
I just got off the phone with Jesse from AERO and Mike from Tempest. They said it's pretty typical. Just looks kind of goofy.
Tony Phillips
05-07-2010, 10:47 AM
I was going to make a statement similar to Bob's pic but a pic is worth a thousand words.
I bet it is nothing to be worried about....
05-07-2010, 10:49 AM
Nice pic, however, the "the rim of the bowl" is not pressed tightly against the gasket. I am told by Tempest that this is typical however.
Tony Phillips
05-07-2010, 11:05 AM
I see now that it appears that the bowl and the flange are 2 parts. It really didn't look that way on the carb. Of course a poorly lit hangar is probably the culprit. Oh yeah and no glasses too.
Tony Phillips
05-07-2010, 11:09 AM
Yep they are....
05-07-2010, 11:27 AM
You know how I know this? I thought the same as you at one time. Till I pulled it apart and said to myself "Self, that ain't no accelerator pump!"
