Old 05-07-2010, 07:26 AM
turbo's Avatar
turbo turbo is offline
Talking is a slick mag core worth $150 to VAF to rebuild?
i am in the process of replacing both mags with 550 hrs since new #4373 and #4370. they are in the plane running fine. the big question is it worth selling to someone for the core to rebuild? the $ would not include the gear or harness. i will be swapping out mine next week. if this makes any sense to anyone than let me know. it may be worth some discussion on the matter, especially the e mag guys. turbo
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 05-08-2010, 12:03 AM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Are you saying you would sell them for $150 each? I will take them both.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 05-08-2010, 05:28 PM
turbo's Avatar
Talking i guess that was what i implyed but at this time ...
i am going to replace the old ones and overhaul the old ones for next time around. thanks turbo
Ed D'Arcy
Old 05-08-2010, 09:32 PM
That?s fine, I figured you where going EI. If not then why are you doing anything more then a 500 hour inspection? Take them off, inspect the points, the cam and set the ?E Gap? (internal timing) and keep on flying. These don?t have a 500 hour life, some will make it to engine TBO and some wont based on many factors like frequency of use and a big one is moisture contamination. If some one told you these have a 500 hour life, they misspoke!
Russ McCutcheon
