Old 05-06-2010, 12:53 PM
bret's Avatar
bret bret is offline
Default Rudder construction -- Take 2
Moving right along on the EMP kit and messed up the trailing edge, could possible work but I do not want to take a chance of in flight failure, say...... spin recovery. what kind of mistakes have others here made that I should be cautious about?
Old 05-06-2010, 01:07 PM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
I have a hard time believing you screwed it up bad enough to risk an in-flight failure, but hard to say without pics. I think most screwups on this are either purely cosmetic or possibly cause your bird to fly crooked.
I stressed out about this task before I did it, but it really turned out to be a non-event for me. Just take your time, work carefully and think it out before starting. This is what I did (gatherered from perusing many posts on here...this is not the only way to be successful though):
1. Alternate shop heads every other one
2. Use pro-seal before riveting
3. Follow Van's directions carefully when riveting
No problems, my edge was within the specs that Van's calls out (cant remember, +/- 0.050"??) but it also wasnt straight as an arrow...so not perfect but you can only see a slight wave in it if you sight directly down the trailing edge which not many people will ever do.
Good luck
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
Old 05-06-2010, 01:43 PM
apkp777's Avatar
apkp777 apkp777 is offline
Step one. - Go look at a Cessna Rudder
Step two - relax as it won't be any worse than what you saw in step one.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 05-06-2010, 02:52 PM
bret's Avatar
No realy, this is bad, so I had it all clecod down with proseal to a 1"X3" 1/4 wall alluminum box 6 feet long, removed, placed every other rivet clecoed back down inbetween rivets, ( do you see where I am going with this )started with backrivet set, setting rivets half way down, go back to fully set and was not getting my width, go to remove and I magicly sheered the the rivet heads and pushed them into the holes I drilled into the box alluminum, ruined the skin. total nut head mistake, only 150.00 for new skins and stiffners but G wiz.
Old 05-06-2010, 02:58 PM
RV7Ron's Avatar
hmm, I stand corrected... shoot, we've all done bonehead things, some just dont admit it, its part of the fun!
Ron Duren
Mechanical Engineer
Denver, CO (KBJC)
RV-7 'Tip Up'
Old 05-06-2010, 03:06 PM
esjacoby77 esjacoby77 is offline
Originally Posted by RV7Ron View Post
...shoot, we've all done bonehead things, some just dont admit it, its part of the fun!
I'll second that! Placing your first order from "the list" is a huge milestone
On your second rudder, follow the instructions exactly...it works.
Old 05-06-2010, 03:11 PM
bret's Avatar
HUM? I have heard that before somewhere.
Old 05-06-2010, 03:21 PM
Jamie Aust's Avatar
Jamie Aust Jamie Aust is offline
Dont give up, we all have done something that needs replacement or re- work.
Is it possible for you to get some help when you are ready to do it again ?
Are you in a local EAA group ?
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
Old 05-06-2010, 03:29 PM
apkp777's Avatar
Yep, rework. Get used to it. Unless it's your second or third plane you'll do plenty.
Tony Phillips
Old 05-06-2010, 03:35 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
I just screwed up the ribs the other day and had to orde new ones for my VS.....I expect more screw ups...just keep moving foward and take it easy!
RV-8 build
DONE!
C-GLOV
http://www.mykitlog.com/Don%20Patrick
