Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
  #11
Old 05-06-2010, 08:28 PM
carl nank carl nank is offline
Default Fuel Boost
WOW! Some good posts here.
I used to have a bonanza some years ago that started fine using the procedures I put into my RV-POH. No wonder I was having problems. way too rich.
Unfortunatly, I tripped while walking and fell down and hurt my right arm. I can hardly lift it so, first flight will again have to wait awhile....
I very much suspect your answers are going to fix my problem. I will notify you when I can get into my airplane again.
Thank you all!!!
Carl Nank
Western KY Lakes Region
N39CN
RV7-A, Superior IO-360, 180HP, Hartzell, Dynon D100, D10 & HS34. Garmin 430W & 327 xp. PS Engineering 8000B audio w/3 light marker beacon. Approach Avionics Pro Hub.
Cut Instrument panel myself. I installed avionics myself. Panel is powdercoated a beautiful dark blue crackle.
