  #21
Old 11-22-2010, 01:03 AM
BSwayze's Avatar
BSwayze BSwayze is offline
Originally Posted by bruceh View Post
My question is how can you access underneath the center tunnel once the pump is plumbed? It looks like with the access hole cut in the middle for snaking the fuel line that there is no way to take the tunnel cover off for wiring, etc. Is the lack of future access a problem, or do you just need to undo the fuel line if you need to get under there?
Bruce,
I considered this question, too. The fuel line unscrews very easily and quickly, and the cover is easily removed. So I went that route. Good luck on your progress, whatever you decide!
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
