Old 05-04-2010, 04:46 AM
PIN 37 PIN 37 is offline
Default Course thread bolts
Can anybody tell me where I can get course thread bolts as used on Lycoming
engines. I cant find them in the spruce catalogue. I want to get some drilled head bolts to bolt my crank sensor on my engine. (not supplied with the Plasma III kit)
Old 05-04-2010, 04:50 AM
Geico266's Avatar
Geico266 Geico266 is offline
They are on their web site.
http://www.aircraftspruce.com/catalo...es/anbolts.php
http://www.aircraftspruce.com/menus/ha/bolts.html
Can't use them funny metric bolts mate.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 05-04-2010, 06:59 AM
I might be a bit confused, but aren't those bolts UNF, not UNC thread?
Old 05-04-2010, 07:02 AM
Geico266's Avatar
You are correct. Hmmmm.
What size do you need?
Old 05-04-2010, 09:26 AM
shuttle's Avatar
shuttle shuttle is offline
Default Lycoming P/No's
Phil,
Don't know of a source, other than your local GA/Piper/Cessna parts supplier. I know that the Piper sales company close to me stocks all the Lycoming parts.
In case it helps, here are the Lycoming part numbers for all the types of bolts I spotted in my Lycoming IO-360-M1B Parts Catalog
Lyc P/No = Description
LW-25-0.50 = BOLT-1/4-20 X 1/2 Long Hex
LW-25-0.94 = BOLT-1/4 -20 X .94 Long Hex
LW-25-1.00 = BOLT-1/4 -20 X 1.00 Long Hex
LW-25-1.13 = BOLT-1/4-20 X 1-1/8 Long Hex
LW-25-1.25 = BOLT-1/4-20 X 1-1/4 Long Hex
LW-25-1.44 = BOLT-1/4 -20 X 1.44 Long Hex
LW-25S1.50 = BOLT-1/4-20 X 1-1/2 Long Drive End
LW-25-1.75 = BOLT-1/4-20 X 1-3/4 Long Hex
LW-31-0.94 = BOLT-5/16 -18 X 15/16 Long Hex
STD-2246 = Bolt-5/16-24 X 1.00 Long
LW-31H0.88 = BOLT-5/16-18 X 7/8 Long Hex Drive
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
Old 05-04-2010, 09:33 AM
shuttle's Avatar
Phil,
I googled one of the above p/no's at random and came up with this website:
http://www.aircraft-specialties.com/...aisle=LYCOMING
Steve Hutt
West Sussex, UK
Old 05-04-2010, 10:11 AM
corbinace corbinace is offline
Default Loctite???
OK, now you have me thinking. I only used red Loctite. Is that maybe not enough? This considering I have a dual LS setup and everything rests on those bolts staying in place.
Old 05-04-2010, 10:15 AM
rocketbob's Avatar
You can get good quality grade 8 bolts that are superior to grade 5's that Lycoming specs from Tractor Supply. Worth noting is that Continental uses AN bolts all over their engines so there's nothing wrong with going that route either. In any case the through bolts provide the critical strength of an engine so any other bolts like the case half bolts merely keep the thing from leaking oil.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 05-04-2010, 10:43 AM
az_gila's Avatar
az_gila az_gila is offline
Smile If you want the real thing...
AERO has them listed....
$2.47 for the 1 inch bolt
http://www.aeroinstock.com/products/...ail/index.html
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-05-2010, 03:22 AM
Corbinace, I too have duel LS, and I think it would be somewhat disappointing to have the engine stop in flight due to the sensor bolts coming loose, hence why I want to safety wire the sensor mount.
These aircraft grade bolts are very difficult to get here in Australia. I still dont know if there is such a thing as a 1/4 x 1/2 UNC drilled head bolt.(aircraft grade), much less where to get them. The places suggested so far dont ship to Australia in any case. (Spruce does ofcourse)
